Zip ties for convertible roof
Popular Reply
For 5 years now, I have had GM warranties and AAA, which means, one of them comes out and hauls the car to the nearest Chevy dealer. As a seasoned garage mechanic, most of todays problems cant be fixed in a well equipped garage, much less in a parking lot.
For those HTC owners who choose to carry a zip tie, I’ll describe the sequence of events as it happened to me.
1. I did hear a slight bang as I put the top down (I was already out of town), I decided I was probably imagining things.
2. Got to my next destination and was putting the top up. I got an error message on the DIC (I can’t remember exactly what it said, something about the top for sure).
3. Getting out to see what the problem might be (although I had already guessed) the driver’s side “headrest” piece was still extended and resting on the roof panel.
4. Here’s the important thing, the switch on the door panel would no longer operate. Obviously it would not continue closing the top since the headrest piece was contacting the roof, but it would also no longer lower the roof (raise the tonneau). It was stuck in that position, with the headrest on the roof panel and the sequence 80% complete. You would not want to drive the car like this for sure. I wouldn’t want it on a flatbed like that either.
5. I put the car in park and turned it off. Fortunately, from there I could use the key fob to operate the tonneau in engine access mode. Hit “Lock” on the fob and then immediately press and hold the convertible top button. That opened the tonneau so I could fold in the headrest piece and use my zip tie to secure it in the retracted position.
6. I then used the key fob to close the tonneau, same sequence, Press Lock then press and hold the convertible top button.
7. DIC message said top closed successfully (or something like that).
8. Obviously don’t try to operate the top again until it’s been repaired. I stopped by the dealership a few days later and used the key fob to do engine access mode to raise the tonneau and show the technician the problem. They ordered the parts and I brought it back 3-4 weeks later for the actual repair.
Note on step 5…..the owner’s manual says “The trunk and convertible top must be closed” but I was able to raise the tonneau in engine access mode while the top was stopped in it’s “jammed” position.
After just having it happen to me, I don’t know why an HTC owner would not throw a couple zip ties into their trunk. Simple thing to do and it’s actually a pretty simple temporary field repair. I was able to go about my business and get it fixed on my schedule.
