C8 General Discussion The place to discuss the next generation of Corvette.
rear caster tool
Old 01-11-2024, 05:21 PM
123vette456
123vette456's Avatar
Default delete
delete sorry wrong post.
Old 01-11-2024, 05:46 PM
wstaab
wstaab's Avatar
You need the GM tool to set rear caster to 0 degrees. Hunter Alignment systems can only measure front caster. My 2022 Z51 was at +.5 to +.6 camber front and rear from the factory. Rear caster was off by +or- 1 degree. Not a problem for a street setting.
I use +1.5 degree camber front and rear, 0 toe front, .10 toe in rear, 0 degree caster rear for a street driven car on performance summer tires with no unusual wear.
BearZ06 (01-11-2024)
Old 01-11-2024, 08:05 PM
mortelec
mortelec's Avatar
https://www.ebay.com/itm/17602212713...mis&media=COPY
Old 01-11-2024, 10:29 PM
GTS Bruce
GTS Bruce's Avatar
You use positive camber?
Old 01-11-2024, 10:43 PM
wrecker3
wrecker3's Avatar
Received 1,492 Likes on 748 Posts
C8 Rear Caster Tool Kent-Moore Block CH-47960-10 and Pins CH-47960-15 and a Angle Gauge.
To rear caster tool
Quick Reply: rear caster tool
