Why This Bolt ?
#41
Sr.Random input generator
These correct External Torx Plus Neiko branded sockets / tools have served me well & there's a deal at Amazon
Ron_Attleboro_MA (04-04-2024)
#42
That picture of the socket appears to have a deep chamfer. You could grind down the edge to lessen the chamfer to make it more forgiving of of-axis use on the low profile heads.
The following 2 users liked this post by RKCRLR:
C5racecar (04-04-2024),
Ron_Attleboro_MA (03-31-2024)
#43
Easier and more secure for automated power tools to grip the bolt head without worries about strippingn it.
mefly2 (04-03-2024)
#44
E-Ray, 3LZ, ZER, LIFT
Received 9,786 Likes
Last week installed a Speedway Composites carbon fiber tube Cross Brace on my E-Ray. The two rear bolts that have to be removed use T-15 Torx bits. Was prepared to do the same 1/2 inch ratchet and 1/2 to 3/8 adapter I used on the brake pad pins.. Appeared difficult to reach since those two bolts are next to the cabin glass on my coupe. Turned out they were only torqued to ~10 ft-lbs and no Loctite was used. I used some Blue Loctite when I reinstalled over the Cross Brace stainless fittings.
SIDEBAR
Recall an issue when our plant decided to use square drive bolts on our welding power supplies. Their reason why, was they were faster and less effort to use in manufacture. In addition to the business/product management I had customer service, phone tech folks, training including repair shop training.
That training service tech manager quickly told me his phone support techs were getting complaints from the service stations. At the time most of our 300+ distributors had repair stations. Their Techs called wanting the square drive tools in all sizes we were using! Got the plant to return to more conventional fasteners!
#45
#46
Yeah, hex is best for me. As I get older, my self labor is getting more expensive, and I can't see myself holding the impact gun perfectly straight 22 times every time I need to drop that cover : ))
#47
Smart not to **** off your customers! Gee are you originally from Canada where it was invented?
#48
