Transmission internal filter (not canister filter)
There's seems to be a lot of confusion regarding the replacement interval of the transmission internal filter. The filter I'm referring to is the one that is replaced by removing the transmission pan, similar to other cars. This is different than the canister filter that's under a 4-bolt cover. One dealer thinks it should be replaced with the fluid at 3 years or 45,000 miles, whichever comes first. Another dealer has no idea when it should be replaced. I don't see anything listed in the owner's manual regarding this filter, only the canister filter. Any ideas or documents anyone can find on this??
"Lifetime" filter unless there is an issue internal to the DCT that would potentially compromise the filter. No need to change during any routine maintenance.
The following 4 users liked this post by Mark9:
its a life time filter just as previous post stated.
Rky Mtn C6 (05-01-2024)
Filter on the inside DCT does not need to be changed at the 3-year mark.
Just make sure they also do the hydraulic flush prior to changing your existing canister and fluid. Lots of dealers will tell you this is not necessary but it is, for any C8's, even the 20s and 21s.
E-Ray, 3LZ, ZER, LIFT
Received 9,765 Likes
Also to get pan off have to move DCT away from cross member. Chuck at dealership where Rick Conti works showed doing his car. He mentioned it was not needed showed what was required to move DCT and said really not needed. Conti said yep I have been doing some aggressive events and think it’s a good idea. IMO he may have been ready to get his next whatever Vette and was going to sell it. Just my guess
I would not change my street driven E-Ray internal filter and did not on my prior 2020 C8 Z51.
Acpantera (05-02-2024)
If it was meant to be changed or the DCT pan removed "periodically" they would not have made it difficult. The DCT has to be supported while support bolts are loosened, and case moved to get the pan off!
Received 1,745 Likes
St. Jude Donor '15-'16,'18
Why so much "debris" being generated and deposited?
Not sure what you are referring to with this remark. But most think that the material being removed by the external canister filter is clutch material. I don't know that we have any direct proof of where it comes from but we do know that the clutches are wet clutches and ride in and share the same fluid with all the other transmission components, valves, and lines. There are also some clutches in the limited slip differential and it also shares the same fluid. There are several threads showing DCT filters cut open at various mileages, and I think it is surprising how dirty they get, and how quickly they get that dirty - especially those that have been cut open during the first 7,500 miles. There was one that was cut open at the 22,500 mile mark, after being replaced earlier, and that one was pretty clean. Entirely anecdotal - but its consistent with the idea that most of the debris is shed in the first 7,500 miles.
