Idle & Trans Issues
Idle & Trans Issues
I have been having a couple issues with my 23 Corvette. I have a real bad stumble during idle and it feels almost how a loose motor mount would feel as you can feel and hear an audible tapping especially when the engine is shut off. Along with that, when the car is revved up around 1300 it get a real bad shake like the motor is turning over and then smooths out. Ran it up to the dealer to look at and GM wants to throw a set of new spark plugs in on Monday see if it fixes the issues before the dealership will look into it further. Has anyone ran into this yet?
CorvetteBrent (05-15-2024)
No codes were thrown. They keep trying to default to the fact that these engines will have a rougher idle than usual per GM. The car also jerks real bad when put into drive. I requested that the main tech sit in the car, so they can hear and feel all the issues
There is a transmission service fast learn procedure that may address the shifting roughness. This procedure "performs a series of individual clutch applications which allows the control module K71to learn initial clutch apply pressures. The control module uses the learn values for clutch control and timing of shifts." The procedure is required after certain components are serviced, repaired or replaced. I do not know if they will perform it just because the shifting is rough. Normally their training is to only perform procedures if led there by a DTC and diagnostic procedure.
It's under warranty, so letting them change the plugs isn't going to cost you anything. and to do that they need to pull off the bottom plates, so if there really is a broken mount they'll be able to see it. Hopefully. If it doesn't fix it (and it probably won't) then they can move on to the next thing. Not much else you can do but let them work through their progression.
The following 2 users liked this post by Red Mist Rulz:
4thC4at60 (05-12-2024),
Received 19,847 Likes
'20-'21-'22-'23-'24
Update from the dealer. They are still installing plugs going on day 3. They found some voltage issues throwing codes. They think it was the aftermarket battery put in before i bought the car. Putting in an oem battery on my dime.
The following 2 users liked this post by hoek30:
CorvetteBrent (05-15-2024),
Ron_Attleboro_MA (05-15-2024)
An aftermarket battery on practically a new 23 C8. What type of aftermarket battery was installed in being such a new build? AGM or maybe a Lithium ion? Somewhat doubt if those two types could cause a prior voltage issue..
The following 2 users liked this post by ArizonaZ06:
RKCRLR (05-15-2024)
Received 4,862 Likes
V Vette (05-15-2024)
Pretty much was told they wouldn’t dig further into the voltage issues with the aftermarket battery being in the car.
Idle is still erratic and missing after the spark plug change. Tech can hear a noise but the service manager suggests letting it get worse and throw a code before they can start to fix it. I’m about ready to punt this POS for another GT500.
