1st Week with shock leak, no end in sight
![](/forums/images/ranks/7k-10k.gif)
Received 4,859 Likes
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
GM is not going to pull parts from assembly line cars to be built to repair a used car under warranty
The following 2 users liked this post by 449er:
Fast Dawg (05-15-2024),
TNBatmobile (05-15-2024)
![](/forums/images/ranks/5k-6k.gif)
Of course not. However, they have been building this platform for five model years. They know what parts are failing or more subject to fail by now. It's ponderous that they don't have any inventory of these items. Saving every little bit of money by using the "we won't inventory anything, just try to get the supplier to provide when needed" thus adding the extra layer of delay.
hawkgfr (05-15-2024)
![](/forums/images/ranks/500-1000.gif)
It is beyond unfathomable how a production company can draw on over 100 years of production experience, the most advanced production software in the world, access to a GLOBAL supply chain,......and still not be able to supply replacement parts when they fail or when a car is in need of repair to their paying customers in a timely manner.
The following 2 users liked this post by See8:
hawkgfr (05-15-2024),
I agree, but rockauto is usually pretty good about not listing parts unless they are available. Usually they let you know beforehand if a part isn't currently available. And many times online stores will provide an estimate of when they expect the backordered part to ship which is more than the dealerships seem to be able to do.
Received 2,577 Likes
Demand hasn't dropped. BG produced 8.5% more Corvettes in Q1 2024 than they did in Q1 2023.
The following 2 users liked this post by Fast Dawg:
jimmie jam (05-15-2024),
Kevin A Jones (05-17-2024)
True. GM has proven that much. But people here were only suggesting that as an immediate solution to gross incompetence or refusal of proper customer support.
![](/forums/images/ranks/1k-2k.gif)
![](/forums/images/ranks/4k-5k.gif)
As for GM stopping their line to rob parts for a repair, there is no manufacturer that would ever do that. Car assembly works by Just In Time delivery, which means there is minimal factory stock nowadays. That means parts typically parts are received for assembly only a few days prior to assembly. Each car build is scheduled into specific slots so the parts can all marry up for build in proper order. Taking a part out of the cycle can actually cause a line stoppage, which they will never risk.
Bottom line is there is normally some service stock, but that is limited and based on previous usage, so if you catch it wrong there could be delay. It is up to Material Planners to make choices, based on supplier capacity, as to where the parts go. How do I know this? I worked for years in an engineering group that supported a factory and had to deal with similarr issues.
Inventory is $$$$, and it is very expensive to stock parts for "what ifs". Though it totally sucks sometimes just happens with any product.
It is called inventory. 3rd party suppliers may stock parts, whereas your local Chevy dealer may not, and they are required to get OEM, current stock, from GM for warranty work or they do not get reimbursed. I am sure if you bought the part, they would cover the labor, but don't count on the dealer working the secondary market.
I agree the reason GM doesn't divert parts from the assembly line is because it is more cost effective for them to produce as many cars as possible instead of supporting warranty repairs. If there are so many cars breaking that diverting parts to support warranty repairs would substantially impact production then that is another problem (I don't believe this is the case). But if it became more cost effective to perform warranty repairs with a slight reduction in production then GM may change their approach.
In many states the Lemon Laws come into play when a car is out of service for 30 days (they don't need to be consecutive) and are in force for a few years. If more people started Lemon Lawing their cars when their cars have been out of service for 30 days it would get GM's attention.
The OP didn't state how long he has had his car but he may be eligible for Lemon Law buyback under the laws in his state once it has been out of service long enough. A dealer shouldn't be able to tell you your car is going to be out of service indefinitely when you have a warranty.
INTIMIDAT3R (06-01-2024)
That must be why they are literally sitting everywhere for sale both new and used....
![LOL](https://www.corvetteforum.com/forums/images/smilies/lol.gif)
![Shrug](https://www.corvetteforum.com/forums/images/smilies/shrug.gif)
JABCAT (05-15-2024)
I think most of the online retailers don't stock the parts, they just make the arrangements to have the parts drop-shipped directly to the customer.
RKCRLR (05-15-2024)
#33
Been doing this for decades. I purchased a new 1979 and at 400 miles the transmission would not shift properly. In for a warranty repair. Order said defective TC, replaced. I kept this car for 27 years and put about 35K on it. At one point the front seal was leaking so I took it to my shop to get the seal replaced. He new I was the original owner and asked me when the "remanufactured" TC was installed. I said WTF, they did that at 400 miles when I had an issue. Brand new car, old part.......
#34
The OP had the car a week… it should have never left the factory….
I had an SHO a million years ago that had a surging problem. Two dealers couldn’t solve it so I wrote every member of the board of directors and got a call from some HQ engineer that said he knew what the problem was but he could not get parts so he took them from the plant assembling new cars… had them shipped to my local dealership and supervised repair.
But regardless one shock being diverted should not shut the line down.
RKCRLR (05-15-2024)
RKCRLR (05-15-2024)
#36
I was strictly speaking of new C8s. I just checked CarGuru and there are a total of 40 new 2024s in your entire state for sale.
24RiptideBlue (05-16-2024),
#37
![](/forums/images/ranks/100-500.gif)
I have a 2020 Cadillac CT5. It was in the shop a couple of months ago for a faulty driver's door handle mechanism. That took over a month for it to be sourced and installed. While to car was being done, the tech scratched at trim piece on the inside of the door. **** happens, and the dealership was good about it and told me they would replace with a new one - all good so far...
When the piece came in, it had a different finish on it..flat grey, instead of the black chrome that the original one was. After talking to the Parts Manager, we discovered that the original part number was discontinued, and they shipped the replacement part.
No beuno, as this certainly did not match the other 9 black chrome pieces in the car. Dealership cannot get the old part number.
Opened a case with the Cadillac Concierge, and it has now been over 2 weeks while they have no update, no part, and no next steps plan. Simple....the part my car came with is not available, even though they confirmed that by federal law, they are required to provide parts for 10 years.
This car is only 4 years old, and they cannot fix my car....what do i do in another 4-5 years? Just bin the car?
#38
#39
There being a law that requires parts to be available for 10 years is an internet myth as far as I can tell. I've challenged people to provide a link to an official source and, so far, no one has been able to do that. I'd like to be proven wrong. The closest I've seen is the Magnuson-Moss act that requires parts to be available during the warranty period.
#40
![](/forums/images/ranks/2k-3k.gif)
But good luck figuring that out from reading the damn thing: https://web.archive.org/web/20130317.../pls/15C50.txt
