C8 General Discussion The place to discuss the next generation of Corvette.
Mouse blocker
Old 05-23-2024, 09:11 AM
SCorvette08
SCorvette08's Avatar
Default Mouse blocker
Does anybody use the mouse blocker? I was thinking about buying one do they work?
Mouseblocker.com
Old 05-23-2024, 09:43 AM
3LZR21U
3LZR21U's Avatar
If you have rodent problems...you've got far bigger issues. This is a band-aid fix.
Fishfryer527 (05-23-2024)
Old 05-23-2024, 10:17 AM
SCorvette08
Default Preventing
Thanks, but not question that was asked
The following 2 users liked this post by SCorvette08:
Acpantera (05-24-2024), tadda (05-23-2024)
Old 05-23-2024, 11:51 AM
Walter Raulerson
Walter Raulerson's Avatar
Get peppermint repels rodents
H Watkins (05-24-2024)
Old 05-23-2024, 11:58 AM
xtroms
xtroms's Avatar
I use Fresh Cab inside the cabin, frunk, and engine compartment, & one on the ground front & back. Never had a problem since. I get them from the local farm store, but I think Lowe's & Walmart has it. The winter I didn't use it those critters made a home in my vette that was a hell of a mess to clean out. Cheap insurance.
Revmanii (05-24-2024)
Old 05-23-2024, 12:02 PM
3LZR21U
3LZR21U's Avatar
If they are a problem for your car, they are a problem for other things as well. That's all I'm saying.
Old 05-23-2024, 04:00 PM
vetteLT193
Support Corvetteforum!
vetteLT193's Avatar
Not necessarily. I've had them get in multiple cars and haven't had them in the house per say (in the garage in the car only). My Chevy volt was particularly amusing as they nested on top of the engine and I'm sure I was driving them around for a few weeks while under battery power. They also made it in my 1966 Corvette and my 1998 corvette. Luckily, no damage so far as I guess I drive them just enough to get them from eating wires.
Cars that don't get driven often are targets for some reason... and your area/landscape is another. I happen to back up to green space (woods) and we are likely more impacted than if we lived in suburban hell where there is no green space.
Old 05-23-2024, 04:42 PM
68/70Vette
68/70Vette's Avatar
The thermal mass of an engine is an attraction for critters. The 500 (SB) to 650 (iron BB) pound engine will warm during the day and at night, when temperatures can plummet, the engine stays relatively warmer. A pronounced effect for cars outside under a car cover. Even in a garage, in areas were daytime temperatures are elevated in daytime relative to nighttime temps, the engine can be a refuge. Particularly if the critter makes a bed out of straw, leaves, stray pieces of cloth.
For a while I had a bare block with heads, valve covers, sitting on a frame. No intake manifold. From the gallery area, between the V banks and above the cam shaft "roof," a mouse was able to enter the underneath of the valve cover and make a nest in the head among the valve spring towers. A disgusting mess of poop, straw, pee staines. Before you ask, it was a Chevy rat motor, not the mouse motor.
Old 05-23-2024, 05:48 PM
CP
CP's Avatar
Received 1,139 Likes on 573 Posts
Go big or go home.
MIKEZ51 (05-25-2024)
Old 05-23-2024, 06:07 PM
TheBigDog
TheBigDog's Avatar
Spread moth ***** around under the car. Works wonders
Ron_Attleboro_MA (05-23-2024)
Old 05-23-2024, 06:20 PM
brocco
brocco's Avatar
I too use Fresh Cab, can find it at Tractor Supply.
I also found the dollar store version of Pine Sol sprayed around my garage helps too, no problems with 2 years usage.
Screw Minny & Mickey
Old 05-23-2024, 06:37 PM
qwazipsycho
qwazipsycho's Avatar
The mice won't get in my car anymore after I took them for a 0-100 launch. Now if I could only drive my house that fast...
Old 05-23-2024, 07:39 PM
Shinobi'sZ
Shinobi'sZ's Avatar
Mouseblocker.com
I use a box of Bounce sheets.
The following 2 users liked this post by Shinobi'sZ:
astepup (05-23-2024), Wife said I could (05-24-2024)
Old 05-23-2024, 07:45 PM
F4Gary
F4Gary's Avatar
2018 C3 of Year Finalist
2016 C3 of the Year Finalist
Doesn't work. They will make a nest out of that stuff.
Old 05-23-2024, 10:11 PM
HAD2HAV2
HAD2HAV2's Avatar
I bought a Mouse Blocker. It took about 4 weeks during last winter before it started working. Mice find a way into the garage to escape the cold. Best place to put the MB is on the floor up against the wall. Try not to block the light beam (that you can't see) to the opposite side garage wall. Other than lights blinking on the MB the devise is silent. My mouse built a nest on top of the C7s cabin filter. So now I have peace of mine. I stopped pulling out the cabin filter just to check.
Old 05-23-2024, 11:22 PM
astepup
astepup's Avatar
Received 1,830 Likes on 682 Posts
I've had great results using them over the years. I also set out baited traps that never get used so for me they work well.
Old 05-24-2024, 06:59 AM
449er
449er's Avatar
Received 4,871 Likes on 3,093 Posts
Good old school spring traps & a dab of peanut butter works better than peppermint, spearmint, moth *****, dryer sheets, etc
The following 2 users liked this post by 449er:
johnodrake (05-26-2024), MIKEZ51 (05-25-2024)
To Mouse blocker
Old 05-24-2024, 07:32 AM
Shirl
Shirl's Avatar
Received 1,599 Likes on 678 Posts
I've used Moth *****. They stink like hell but work. I put the bags around the car.
Old 05-24-2024, 08:25 AM
hawk02
hawk02's Avatar
Received 1,573 Likes on 626 Posts
I snowbird to Florida in the winter and have taken my C8 with me. My condo is on a peninsula with the ocean on one side and the mangroves and intercoastal water on the other side. The ground level of my Condo is a parking garage with 33 spots for owners and guests to park a vehicle.
River rats are a big issue on the peninsula. Last year the little bastards got under the hood of the frunk and nibbled on the piece of trim that diverts water off the windshield. This year they nibbled enough of it to the tune of $500 worth of damage. I used peppermint repellant to spray around the entire car every night plus I rolled up a hand towel soaked in peppermint repellant and stuffed it on the driver's side where the frunk meets the windshield.
Until I can come up with a better solution to deal with the rats, my C8 will probably remain in Ohio from here on out.
Cumbers (05-26-2024)
Old 05-24-2024, 01:53 PM
hawkmaster
1st Gear
hawkmaster's Avatar
This is the best thing I have found for mice in a long term (months) storage situation. I use this for boats cars etc in my pole barn. I jack the car or trailer up and put it on jack stands and have the jack stand IN the bucket. The mice cant really climb up the bucket and problem solved. In the past I've had damage from mice on both my C6 and boats but since using the bucket trick, no damage or evidence of mice in the cars or boats for several years. This is a yearly process for winter. During the summer the (now c8) is in a garage that is mice free
Quick Reply: Mouse blocker
