Sponsored by: Wheel Design
Mid engine maintenance cost?
Old Oct 29, 2018 | 06:16 PM
JoeHat's Avatar
JoeHat
Default Mid engine maintenance cost?
Im thinking better include an extended warranty if buying one of these. Not the easiest cars to work on i.e. Ferrari, Porsche, Lambo, Audi. It would be nice to keep a front engine model available for us average middle income joes?
Popular Reply
Oct 30, 2018, 12:20 AM
LawrenceFromTorrance's Avatar
Originally Posted by Sunset-C6
If you can't afford to maintain it you can't afford to buy it.
So tired of hearing this, it's the answer to everything. Because I bought something expensive I should expect poor design (high cost of maintenance) or expect to get ripped off because I have money. Part of buying something that cost more than others is better design, more reliability. At least that's what I do when I buy something more expensive than the alternate choices, I expect it to last longer and be better made so in the long run I made a good choice. I know this is not a good analogy but as I first said, so tired of hearing this
Old Oct 29, 2018 | 07:38 PM
dexterkatt's Avatar
dexterkatt
Lamborghini Gallardo - $5,000 clutch change, $200 oil change, $800 hydraulic hose change.
C8 - who knows.
Old Oct 29, 2018 | 08:35 PM
Tom73's Avatar
Tom73
C8 - who knows.
advantage of a using Chevy engines, $75 oil change.
Old Oct 29, 2018 | 09:01 PM
Sin City's Avatar
Sin City
2020 C8 of the Year Finalist - Unmodified
Its not the parts costs. Its labor. Mid engine cars are more complicated and difficult to work on. So, it's more labor.
Under warranty no one cares. After warranty everyone cares.
Old Oct 29, 2018 | 09:06 PM
fasttoys's Avatar
fasttoys
Audi R8 V8 A/C compresure change out 800 parts 5000 labor, ebgube needs to be pulled. Mag Ride shocks, 4 replaced and installed at dealer is 9200 dollars. ME cost more to work on just because of the placement of the motor.
Old Oct 29, 2018 | 09:45 PM
fpfaeth's Avatar
fpfaeth
I bet the Chevy engineers worked all of this out. No way any Corvette owner would put up with extraordinarily high maintenance costs -- it would violate the unstated contract Chevy has with Corvette owners. Recall too that Lamborghini, McLaren, and Ferrari produce less than 8,000 cars per year (I believe Ferrari is the largest producer, at about 7600 vehicles). These manufacturers can't work out the maintenance kinks because they don't have the run span to do so and owners are not complaining. As the owner of a C7 Z06 and some exotics, I remain amazed at every aspect of the Corvette, and bet the remarkable value, sheer competence and world class characteristics will only be enhanced.
Old Oct 29, 2018 | 09:56 PM
Sunset-C6's Avatar
Sunset-C6
Old Oct 29, 2018 | 10:00 PM
Michael A's Avatar
Michael A
I don't recall the Fiero or MR2 all that expensive to maintain.
C7 isn't all that easy to work on either. Try changing the clutch or torque converter.
Old Oct 29, 2018 | 10:07 PM
fpfaeth's Avatar
fpfaeth
Or installing a remote clutch line bleeder.
Old Oct 29, 2018 | 10:15 PM
twilhelm39's Avatar
twilhelm39
So tired of people bitching and moaning. Keep your C5,6,or 7 and let those of us that can buy a c8 buy one. I've never flinched at my maintenance on my Porsche.
Old Oct 29, 2018 | 10:54 PM
NY09C6's Avatar
NY09C6
Oil and brake changes will not cost an arm and a leg. DCT clutch replacement will and drag racers will need them replaced.
Old Oct 29, 2018 | 11:25 PM
Tom73's Avatar
Tom73
I don’t see maintance on a ME being any worse than a front wheel drive car. Both have engine/transmission/differential as a single unit setting between the drive wheels with all the associated drive shafts, shocks, springs, etc. Those high maintenance costs are for exotics and people except high cost for them. But here we are dealing with a Chevrolet where those types of high costs are not acceptable.
Old Oct 30, 2018 | 12:20 AM
Old Oct 30, 2018 | 03:34 AM
prinzSD455's Avatar
prinzSD455
Finalist 2020 C4 of the Year - Unmodified
When a mid-engine like Ferarri, Lamborghini, or McLaren are brought in for service, how do the techs get to the engine. Do they drop the motor or remove the rear and rear side fenders to get to it. Seems it would be difficult to lean into the engine bay of a mid-engine that's buried in the middle as opposed to a front engine car.
Old Oct 30, 2018 | 08:48 AM
Foosh's Avatar
Foosh
It all depends upon the design. My ME Lotus had everything on the engine as easily accessible as any front-engine car.
Old Oct 30, 2018 | 09:45 AM
fpfaeth's Avatar
fpfaeth
The last 'production' Ferrari that needed a 'drop the engine' procedure to do anything more than an oil change was the 355, about 20 years ago. As Foosh wrote, all depends on design. The V12s are simply really complex and tightly packaged, which makes working on them difficult. On my ME McLaren, maintenance is pretty simple, once you take off all the under panels, which can take some time and patience. On the positive side, it has no belts, so that's one hassle I'll never need to deal with. Brakes are simple (identical to Z06).
Old Oct 30, 2018 | 09:51 AM
Tally Ho's Avatar
Tally Ho
From: Out Where the Buses Don't Run, Eglin AFB/ Niceville FL
2022 Corvette of the Year Finalist -- Modified
2021 C6 of the Year Winner - Modified
2020 C6 of the Year Finalist - Modified
I agree. My F430 engine components were accessible from underneath. Parts were pricey, though which is why I no longer have it. A water pump change, parts and labour, was $5K. I did install headers and aftermarket exhaust in my garage and a brake pad swap was as simple as the C7.
To Mid engine maintenance cost?
Old Oct 30, 2018 | 10:19 AM
z06801's Avatar
z06801
I think the ME will be designed around ease of maintenance. They know they'll be serviced at their dealerships. My 911 turbo oil could be changed very easy in about a 1/2 hour, access to all four drain plugs was simple. The whole motor could be quickly dropped about 4 inches to allow more room on top. It's all about design and how it's put together.
Old Oct 30, 2018 | 10:25 AM
TBIRD57's Avatar
TBIRD57
C8 - who knows.
great example of gouging......
Old Oct 30, 2018 | 11:44 AM
bgspot's Avatar
bgspot
Exactly. You buy sports/performance cars for the thrill of driving not practicality and affordability . Thats what economical cars are for...
I will say thats the problem with Corvette though. Its like the only performance car i can think of that has such unreasonably high expectations! People want it to have super car performance, exotic looks (but STILL maintain that american not european look), do cross country road trips, be DIY friendly, all while still clocking in near the price of the current C7 stingray!!!
