Sponsored by: Wheel Design
Engine/Trans/Diff layout
Old Nov 17, 2018 | 02:42 PM
Tom73's Avatar
Tom73
Default Engine/Trans/Diff layout
I had been thinking that the ME would use a traditional transaxle (transmission/differential in one unit) with the engine bolted to it. But in reading a lot of the threads I am feeling that some feel it will be like a C7 with a separate transmission bolted to the differential and then the engine bolted to them.
Does anyone have any real insight on this?
Seems that the traditional transaxle would be better space management as the C7 configuration would be much longer.
Old Nov 17, 2018 | 03:48 PM
range96's Avatar
range96
Engine, differential, gearbox.
Old Nov 17, 2018 | 04:01 PM
Tom73's Avatar
Tom73
Thanks, that is what I was wondering.
So I can do more research, what is the source of that data?
Old Nov 17, 2018 | 04:37 PM
Skid Row Joe's Avatar
Skid Row Joe
Engine, *AWD differential, gearbox.
Old Nov 17, 2018 | 04:49 PM
Tom73's Avatar
Tom73
So the gearbox behind to differential. That would make for a more compact design, moving the engine back several inches.
Old Nov 17, 2018 | 04:54 PM
Zaro Tundov's Avatar
Zaro Tundov
Based on the leaked CAD drawings the C8 will have a stonking transaxle.
Possible technical specifications, but these are for Tremec's front-mounted DCT, not for the rear mounted transaxle in the C8. The technical sheet implies that the specs apply to RWD, AWD, and transaxle designs, and the torque limits are both within about 50 lb-fit of the rumored engines (LT1 successor and a 'Vette version of Cadillac's 4.2TT DOHC V8).
Old Nov 17, 2018 | 05:49 PM
Shaka's Avatar
Shaka
Those are not xaxles. The new gearbox does not have a model number yet. GM has been working with Tremec for over 4 years now and since then, the Mexican based company has purchased the Belgium company, Hoerbiger Drivetrain Mechatronic who is the OEM xaxles for German makes. The gearbox above is ZF whom GM has also been talking to. With the Hoerbiger connection, a 6 speed manual is available for the 500hp OHV engine without a problem. We shall see soon enough.
Old Nov 17, 2018 | 06:01 PM
Zaro Tundov
Ok, so where is the differential in that CAD drawing? Because what I see is a single mechanical unit behind the engine that combines the functions of the gearbox and the differential, i.e., a transaxle.
Old Nov 17, 2018 | 06:03 PM
Tom73's Avatar
Tom73
Good info, thanks. So looks as if we could have multiple transmissions: DCT, Manual, and, maybe, an old fashion automatic.
Old Nov 17, 2018 | 08:32 PM
NY09C6's Avatar
NY09C6
The leaked CAD images clearly show what we are getting.
Old Nov 18, 2018 | 12:01 PM
Shaka's Avatar
Shaka
Not true. The CAD files were explored and published 4 years ago. The model numbers above refer to Tremec gearboxes behind a FE car. They won't be ZF units.
Old Nov 18, 2018 | 12:09 PM
Zaro Tundov
That's not true. The Tremec technical specs PDF states in regard to those model numbers:
Modular design for rear-wheel drive (RWD), all-wheel drive (AWD) and trans-axle platforms
Old Nov 18, 2018 | 12:16 PM
Shaka's Avatar
Shaka
Sorry, my comprehensions is not great, I based my comment on the front engine units you posted without reading your text. The CAD file shows a ZF Xaxle.
Old Nov 18, 2018 | 12:18 PM
Shaka's Avatar
Shaka
I'm talking about NYs statement. What are you talking about?
Old Nov 18, 2018 | 12:29 PM
Tom73's Avatar
Tom73
So, it looks like nobody really has any real idea of what is coming other than a dated cad drawing that shows some type of unknown transaxle.
We all probably need to preface any and all of our comments with “in my opinion”
Old Nov 18, 2018 | 06:35 PM
Bikerjulio's Avatar
Bikerjulio
I've been on this forum for most of the year and I've seen no discussion that the car will have anything other than an integrated transaxle bolted up to the engine. Nothing else makes sense. Although there are wishes for a manual, not one of the test cars seen so far is a manual. They have all been DCT.
There has also been endless debate about the leaked CAD which shows a ZF transaxle. No one knows the true provenance of that drawing. It could simply have been a concept. Counter to that, the auto press has consistently been reporting for several years now that GM is working with Tremec on a 7-speed DCT transaxle. And certainly Tremec have such a thing.
Hopefully we don't have too long to wait.
Old Nov 18, 2018 | 07:52 PM
Tom73's Avatar
Tom73
How can you tell if a car has a DCT? (Serious question)
To Engine/Trans/Diff layout
Old Nov 18, 2018 | 08:01 PM
NY09C6's Avatar
NY09C6
So you are saying it will be FWD?
Old Nov 18, 2018 | 08:04 PM
NY09C6's Avatar
NY09C6
They heavily screw with fueling and ignition cuts to make it shift smooth and protect the delicate clutches and input shafts. The sound when shifting is unique.
Old Nov 18, 2018 | 08:18 PM
Tom73's Avatar
Tom73
No way to tell from pictures, right. So must have a video with good sound. What type of sound am I looking for?
