Sponsored by: Wheel Design
C8 gets mode-variable electronic braking
Old Jul 23, 2019 | 04:08 PM
RapidC84B's Avatar
RapidC84B
Default C8 gets mode-variable electronic braking
Harlan confirms its e-boost and not brake by wire - https://www.corvetteforum.com/forums...n-charles.html
EDIT - This is an old post before we received more info. The C8 is not the Brembo "brake by wire" system linked in posts below. It's fully hydraulic but with electric boost. The car mags keep spouting "brake by wire" as if there is no hydraulic connection. That is false.
See better thread here - https://www.corvetteforum.com/forums...they-work.html
Wow... hope I like this on track. After 20 years tracking these cars I hope they don't hide too much feedback.
https://www.autoblog.com/2019/07/23/...stable-brakes/
Old Jul 23, 2019 | 06:38 PM
RonC7's Avatar
RonC7
What happens if the electrical system fails? No service brakes, no parking brake. At least with the current system you still have brakes, just requires a lot more effort to stop after a couple applications.
Not too sure about this "feature." I don't care if a car goes, but it damn sure has to stop.
Ron
Old Jul 23, 2019 | 07:21 PM
RapidC84B's Avatar
RapidC84B
Ron
Good question... I have no idea. I’m assuming the pedal still pushes something hydraulic? No?
Old Jul 23, 2019 | 07:22 PM
BIG Dave's Avatar
BIG Dave
Ron
Similar concept to throttle-by-wire and I never hear of that failing.
Old Jul 23, 2019 | 07:40 PM
RonC7's Avatar
RonC7
If throttle by wire fails the engine doesn't respond or throttle control fails in some way. Worst case, you push the ignition button and kill the engine. You still have brakes.
I believe the throttle pedal has 2 potentiometers that are compared in the software.
But I see lack of brakes as a much more significant safety issue than lack of throttle (yeah I remember Toyota stuck throttle issues).
Ron
Old Jul 23, 2019 | 10:08 PM
jcp911s's Avatar
jcp911s
Sounds like this just controls the "boost" or "assist"... there is still a hydraulic connection between the mc and the calipers. So... if the vacuum booster on your current system fails, you can still stop, provided you can do 450lbs squat on a leg press. Its the same, just different.
Your power steering works the same way... its electric... the "feel" is entirely simulated.... so the "brake feel" will be entirely simulated... and frankly, if you have ABS (which pretty much every car has today), your brake "feel" is already simulated...
Old Jul 23, 2019 | 10:38 PM
RonC7's Avatar
RonC7
If you read the article it does not seem that there is a hydraulic link between the brake pedal and the rest of the system:
"The driver presses down on the brake pedal, sending a signal to a computer. This “force” is then transferred to all the brakes using traditional brake fluid. Chevy is able to eliminate the conventional vacuum-based power brake system, which it says “provides an advantage in efficiency.”
There is no mention of an emergency braking system that will operate in case of electrical or component failure. Hopefully it is there and is just not mentioned in the article. I can't imagine a car meeting any kind of safety standard without something.
We'll just have to wait for the full story on this.
Ron
Old Jul 23, 2019 | 10:41 PM
RapidC84B's Avatar
RapidC84B
I can’t imagine a braking system with no hydraulic link.
Old Jul 23, 2019 | 10:42 PM
Sin City's Avatar
Sin City
2020 C8 of the Year Finalist - Unmodified
The electric braking on the Alfa Romeo Giulia is the one thing I really dislike about it. It just feels "weird".
Old Oct 16, 2019 | 08:39 PM
64Scout's Avatar
64Scout
was it Toyota that had a dumpster fire of a recall because the throttle by wire systems went haywire in a few cars? Back around 02 iirc
Old Oct 16, 2019 | 08:43 PM
64Scout's Avatar
64Scout
If they wanted to just get rid of the vacuum booster, why not go to a hydro boost setup? It's already tried and true.
Old Oct 16, 2019 | 08:47 PM
PreservedSwine's Avatar
PreservedSwine
I've read (heard) this is in preparation for the yet to be announced hybrid model. Does that make sense?
Old Oct 16, 2019 | 11:28 PM
50MileSmile's Avatar
50MileSmile
Ron
I heard at a dealer preview that all you have to do is pull on the emergency door latch cable and it throws out an anchor.
Actually, according to Brembo’s July news release on the whole C8 braking system, “for the first time in Corvette history, the eighth generation will come with a Brembo Electronic Parking Brake (EPB). The Brembo EPB reduces part complexity, with the elimination of a brake pedal, brake lever and associated cables. Activation of the parking brake is as simple as pushing a button. The new design for the GM EPB delivers a 3 kg (6.6 lbs.) per car weight savings over the previous drum-in-hat style system.”
Old Oct 17, 2019 | 12:24 AM
vampire81's Avatar
vampire81
"​In the event of a total loss of electricity, the conventional hydraulic safety system will take over for the Brake-By-Wire system enabling the braking system to operate on the front wheels, thus meeting the relevant legislation for secondary braking."
source
Old Oct 17, 2019 | 09:58 AM
lgodom's Avatar
lgodom
The elimination of the traditional vacuum booster also allows the hood line to be lower per Josh at the NCM event.
Old Oct 17, 2019 | 10:13 AM
RapidC84B's Avatar
RapidC84B
source
No... this is not what the C8 has. Please stop repeating this bad info. The C8 has a traditional hydraulic brake system with electronic boost.
I made this thread when we didn't have much info... the car mags keep repeating "brake by wire", but it's not.
Old Oct 17, 2019 | 10:17 AM
Racer X's Avatar
Racer X
Couldn’t this also allow programming line-loc in?
Old Oct 17, 2019 | 06:30 PM
MitchAlsup's Avatar
MitchAlsup
a) you still have brakes
b) they are not as power assisted as before
c) a red light will illuminate on the dash
To C8 gets mode-variable electronic braking
