Is GM going to continue with the AFM in the C8? I ask this because of this in C&D:
"The additional output, which jumps from 455/460 hp and 460/465 lb-ft in the LT1 to 490/495 hp and 465/470 lb-ft in the LT2 (the higher figures are with the optional performance exhaust, which adds a second set of flapper valves)"
The words "second set of flapper valves", to me, means that the C8 WILL have AFM stuff in it.
Anyone know for sure?
Don't know of it will have AFM or not, but what you are referring to sounds more like valving in the exhaust.
The OP quoted Car & Driver making a statement that applies to NPP, not AFM. The exhaust bypass valves of NPP improve horsepower slightly but have nothing to do with cylinder deactivation. The answer to his question is that the LT2 does offer cylinder deactivation.
You missed the C&D statement that I included that talks about a second set of flappers. Obviously, the FIRST set of flappers is the set of AFM flapper valves.
Nonsense. He didn't miss anything; you did. Flapper valves in the exhaust train have nothing at all to do with AFM. AFM has to do with cylinder deactivation at suitable times. It shuts off 4 out of 8 cylinders to save fuel. How could you possibly misunderstand that? "AFM Flapper Valves: Do they come with a can of Blinker Fluid?
The new C8 is reported to have AFM. To clarify some of the discussion here, we can look back on six years of C7 history (talking base and Z51 cars, not Z06/ZR1's). The standard non-NPP C7 exhaust has two AFM valves before the mufflers that operate in concert with cylinder deactivation. The NPP exhaust adds two more valves at the exhaust tips that open and close in different operating modes, driving conditions, and rpm's. I expect the C8 will have a similar arrangement.
You've obviously missed all the threads about a CEL being set when the AFM valve actuators are removed from the exhaust. The AFM valves are there to change the crappy exhaust sound when the engine is running on 4 cyl.
I certainly hope GM doesn't decide to abuse the DCT clutches as a means to minimize drivetrain
vibration when in V4 mode like they did with the A8 torque converter clutch. Many believe it is the
underlying cause of A8 shudder issues. If they do, hopefully Range will be able to provide a
solution.
solution.
Very true. Will be interesting to see how this new DCT does with AFM and if there will be more vibration in 4 cyl. mode.
LOL...I think you own a C7 right? You’ve probably got them AFM flapper valves too! Most do!
How noticable is the AFM in 4 cyl mode in the Base C7?
Not really noticeable at all I don't think. Tadge said one of the reasons they went with a TC tranny is so the convertor would soak up the 4 cyl vibration.
