Will Magnetic Ride Control soften the ride of the Z51 in touring mode to as quiet and soft as the base model in the same mode? Or will the stiffness of the Z51 suspension make the ride harsher even despite the Magnetic Ride Control set to the most comfortable mode? Conversely, will Magnetic Ride Control make the touring mode even smoother and quieter than the base model in the touring mode?
For a C7:
Base is softest ride.
Adding MSRC to base allows you to firm up the ride when needed. (Not currently an option for C8)
Z51 has stiffer springs, sway bars, and shocks. The ride is firm.
Adding MSRC to Z51 includes reverting the spring rates back similar to base spring rates. The ride in Tour is similar to base but perhaps slightly firmer.
I don't believe the base model has any way to change how the car rides. You pays your money and you takes your chances.
The question is still a good one past z51 owners with msrc can answer... Is touring mode from MSRC comparable, better, or worse (primarily in terms of comfort) to the non-z51 suspension?
For a C7:
I just traded a 2014 Z51 without MRC for a 2019 Z51 with MRC. The extra stiffness of the Z51 suspension comes through even in Touring Mode with MRC and in Race mode the car is an absolute beast when it comes to cornering! I have also owned a base C6 (no Z51 package) without MRC and that ride was much softer. Just another reference that may or may not be relevant to the question...
If you're debating whether to get MRC with Z51? Believe me you won't be disappointed if you're going for performance...it is much superior to the standard Z51 package! Good luck!
I've never driven a completely base C7. My C7 was a FE3 non-mag Z51. The FE4 Z51 uses softer springs so it can be softer in tour mode and uses the mag shocks to firm it up for sport/track modes.
The Z51 will be stiffer than base as others have explained. Comparing a base model with and without MSRC is an interesting question.
My 17 Z06/07 with MSRC was so stiff, I could tell the difference between a nickel and a dime when I drove over them. Not fun on bumpy roads, but a cornering/handling beast. The MRC software update Chev introduced in 2018 softened the ride considerably in tour mode. It's standard on 2019's so I expect GM will push this learning into the C8 and the base model with MSRC tour mode should be close to the non MSRC car. Again, moving to the Z51 stiffens things up a bit.
This is my guess at how the suspension will stiffen:
1) Base model without MSRC - softest
2) Base model with MSRC - also soft in tour mode. Ability to stiffen in more advanced modes
3) Z51 without MSRC - stiffer than both 1) and 2)
4) Z51 with MSRC - stiffer than both 1) and 2), the same as 3) in Tour, with the ability to stiffen in more advanced modes
Disagree... I can tell you 100% a FE4 in tour will be softer than FE3 as the FE4 has softer springs.
Your car felt stiff because you had the Z07 package with the stiffest springs GM put on the C7.
I guess I guessed wrong. Wait, was that statement 100% wrong?
3) Z51 without MSRC - stiffer than both 1) and 2) 4) Z51 with MSRC - stiffer than both 1) and 2), the same as 3) in Tour, with the ability to stiffen in more advanced modes
This portion is wrong... the Z51 MSRC in tour will not be the same as Z51 w/o. It is much softer. MSRC in sport mode is similar to non-mag and track mode is stiffer.
Just keep in mind, trying to compare former C7 experience to what a C8 might feel like is apples and oranges no matter how you try to rationalize it. Two completely different suspensions, shocks, and on the C8 the MRC is 4th generation. I don't think you will get an appropriate comparison. What ever the differences were on the C7 between base Stingray, and Z51 don't matter for what a C8 might be.
Regardless of Z51 or base, the single biggest factor in softening the ride is replacing run-flat tires with non-runflat. You can also replace the Z51 or Z06 factory shocks with aftermaket Bilsteins and soften the ride while enhancing performance. Another member reported non magnetorheological OEM factory shocks cost GM $9 each. That should give a clue as to quality.
I have a 2017 C7 Grand Sport with the base (non Z07) suspension, which is also the base Z06 suspension. I also had the MRC software update done. In "touring", the softest setting for daily driving, the MRC gives a very comfortable ride even with that track ready suspension under me. No harshness at all. Still feels like a sports car in that the car is not "floaty", but quite comfortable. No idea if a C8 will be exactly the same, but the MRC is amazing. I am running a new set of OEM MPSS run-flat tires.
Modern run-flat tires are not harsh like four or five years' ago, at least not when mag ride is available.. See my post immediately above.
assuming chevy will add MRC in 2021 model without Z51 requirement.
On a C7 the non-Z51 had the softest ride. The Z51 w/MSRC was slightly firmer. There was a MSRC update that softened the ride some but I don't know if softened it to the point of a non-Z51 C7.
The MotorTrend article said the C8 non-Z51 and Z51 w/MSRC in Tour were comparable.
Adding MSRC to a non-Z51 C7 really didn't make the ride any softer. It allowed you to firm up the ride in other modes and take advantage of the MSRC attributes.
