Sponsored by: Wheel Design
Water entry around engine
Old Jan 4, 2020 | 08:00 PM
lgodom's Avatar
lgodom
I discussed this with Josh Holder at the NCM showing. Water is going to get into the engine bay through the vents in the cover and the engine is going to get dirty. There is a drain path for water under the vents. The connectors are water tight and the car can be driven in heavy rain. I’ll bet green tree pollen in the spring will find its way into the engine compartment if left outside.
Old Jan 4, 2020 | 11:47 PM
firstgear's Avatar
firstgear
2019 Corvette of the Year Winner
St. Jude Donor '15
Easy way around the water is a very high snorkel!!
Old Jan 5, 2020 | 12:13 AM
vetteship's Avatar
vetteship
No issues at all, and just like water intrusion in the Huracan engine bay area, the '05/'06 FGT have open vents around the rear clamshell glass, open vents in the front hood, open vents in the rear, wash and dry (any method you like) and you're good to go
Old Jan 5, 2020 | 01:11 AM
GetOutOJail's Avatar
GetOutOJail
Taste has actually responded to this question asked of him and his answer was very precise, he suggested that the engine bay was designed for rain and everyday water intrusion under driving conditions but he stressed that it would be best not to use any pressure washing or jetted sprayer directly over the engine vents and to definitely avoid commercial car washes. This seems to make the most sense regardless. You aren’t going to destroy the engine right away by hosing through the vents. The suggestion was though that it could lead to greater corrosion with time. I personally think that everyone is going to do their own thing.
Old Jan 5, 2020 | 10:55 AM
Lacquer's Avatar
Lacquer
There is really no more issue with a mid engine getting water in the engine compartment than a front engine. What I do when I wash our mid engine cars is lay a towel (several depending on openings) over the engine and tuck it in so I can close the engine cover over it. Once I am done with the water and blowing off, I open the engine compartment and use that towel for dabbing little areas and doing windows. Makes it quick and easy.
Old Jan 5, 2020 | 11:14 AM
BIG Dave's Avatar
BIG Dave
A vented rear hatch is nothing unique.
Old Jan 5, 2020 | 11:59 AM
The Successful Plumber's Avatar
I have to dry off the engine compartment and underside of the hood of my C7 when I wash it, the C8 will be no different. Driving the C8 in the rain might be messier.
Old Jan 5, 2020 | 04:17 PM
CZS's Avatar
CZS
I would think it would be fairly easy to cover the vents on the engine hatch while the vehicle is being washed, if someone were overly concerned about it.
Old Jan 15, 2020 | 09:37 PM
spinkick's Avatar
spinkick
My question is, how fast does the engine bay get dirty? Why have all this glass to display the motor if its gross most of the time.
Old Jan 15, 2020 | 09:51 PM
lgodom's Avatar
lgodom
Without the glass you wouldn’t be able to see out the back using the rear view mirror. The side grills on the hatch and the bottom of the hatch glass are open to the elements. It’s going to require keeping the inside of the glass hatch and the glass between the engine and the passenger compartment clean for optimum rearward visibility.
Old Jan 15, 2020 | 09:58 PM
spinkick's Avatar
spinkick
Gotcha. I know a test driver and they say its filthy most of the time. So maybe in practice the convertible is the right choice.
Old Jan 15, 2020 | 10:08 PM
Phil1098's Avatar
Phil1098
There is absolutely nothing better than this for an engine.
http://www.s100.com/portfolio/s100-total-cycle-cleaner/
While it's motorcycle cleaner, it won't attack and discolor plastics and such. I have had cars that I prepped for competition concourse events using this.
Old Jan 15, 2020 | 11:50 PM
  #33
4thC4at60's Avatar
4thC4at60
Originally Posted by dmaxx3500
don't drive it in the rain
Been driving my mid-engine Ferrari in the rain for the past seven years..... been driving Corvettes for 30 years in the rain.....
Old Jan 16, 2020 | 09:31 AM
  #34
Jeff V.'s Avatar
Jeff V.
It's almost like they're designed to be able to do that or something.
Old Jan 16, 2020 | 09:38 AM
  #35
RapidC84B's Avatar
RapidC84B
Considering there are fans in each side cove to blow air through the engine bay, I expect hosing down the engine will be part of normal washing. Imagine being in a semi truck's road grim spray on a rainy day... that's going to get all over, but these engines all use weather-pack electrical connections and are made to be washed.
I do recall a TSB from the C5 days where the knock sensors in the valley cover would corrode from folks who washed their engine bays frequently then didn't go drive and let the engine eat evaporate the water. Water would get under the manifold and into the knock sensor cavities. Knock sensors aren't in the valley anymore so non-issue.
Old Jun 12, 2026 | 10:51 AM
  #36
bobmugge's Avatar
bobmugge
Cruising
I use a blower first then a microfiber towel. I wash it then dry it. Takes literally 2 minutes at most.
Old Jun 12, 2026 | 11:02 AM
  #37
Kbmwgt's Avatar
Kbmwgt
Get a good grip on the car and turn it upside down and shake it. Don't drop it. That would be bad.
To Water entry around engine
Old Jun 12, 2026 | 01:19 PM
  #38
dbirdhouse1's Avatar
dbirdhouse1
Default Works well
Bought some soft plastic panels that fit over the engine venting, takes care of most of it for 60 bucks
Old Jun 12, 2026 | 01:30 PM
  #39
Rapid One's Avatar
Rapid One
Originally Posted by clyde8452
Ive noticed it looked like the venting around the new motor is open from the outside right to the engine bay ? I wonder if this will be different on final production cars ?
Its not water entry its more like a water fall. N-Joy the video
Old Yesterday | 02:27 PM
  #40
DWS44's Avatar
DWS44
2022 C8 of the Year Finalist - Modified
2022 C7 of the Year Finalist - Unmodified
I like how y'all picked up a dormant 6+ year old thread and running with it again.
