Sponsored by: Wheel Design
Pull engine to remove passenger side valve cover?
Old Aug 8, 2019 | 03:58 PM
RapidC84B's Avatar
RapidC84B
Default Pull engine to remove passenger side valve cover?
Going to be interesting to see what all you can do with the engine in the car. The dry sump oil fill tube is secured to the passenger side valve cover. If that tube comes off, then you'll be able to get at the valve covers in the car. If not, well then out comes the engine.
Old Aug 8, 2019 | 04:06 PM
Bigjsn250's Avatar
Bigjsn250
I'm going out on a limb and saying the GM engineers though of that and it's removable without removing the engine. My guess on the spark plugs is go in from the bottom, remove coil pack and the spark plugs are fairly easy to change. The easiest thing to change on the car will be the front O2 sensors
Old Aug 8, 2019 | 04:09 PM
RapidC84B's Avatar
RapidC84B
Agree... just wondering how that plastic tank arm would come off the main tank if it's not all one piece of plastic. Hard to tell.
Old Aug 8, 2019 | 04:11 PM
village idiot's Avatar
village idiot
Never thought I'd see the day when a 60k car came with manifolds like that.
Old Aug 8, 2019 | 04:45 PM
RapidC84B's Avatar
RapidC84B
Agree... and actual viewable valve covers that look pretty! the C7 covers were covered in humps for the PCV chambers and the C5/6/7 all had coil packs on them. C8 puts them down low and developed a nice smooth cover.
Old Aug 8, 2019 | 04:57 PM
C8Jake's Avatar
C8Jake
Z51 gets four-into-one stainless steel equal length headers.
Base C8 gets 4-2-1 cast iron manifolds.
Old Aug 8, 2019 | 05:01 PM
ZeeOSix's Avatar
ZeeOSix
I doubt the oil filer tube is attached to the valve cover. It looks like there are a couple of mounting tabs along the run of the tube, so it probably attaches to something besides the valve cover.
I just hope the plastic oil tank can take the heat over time and not ever spring a leak.
Old Aug 8, 2019 | 05:11 PM
RapidC84B's Avatar
RapidC84B
Huh? You can clearly see the large red support pedestal that the filler tube attaches to. This is so you don't transmit leverage to the long tube while you're opening or closing the fill cap and break it over time.
Old Aug 8, 2019 | 05:22 PM
C8Jake's Avatar
C8Jake
Doubt the oil filer tube is attached to the valve cover. It looks like there are a couple of mounting tabs along the run of the tube, so it probably attaches to something besides the valve cover.
makes sense
Old Aug 8, 2019 | 07:12 PM
16falcon's Avatar
16falcon
St. Jude Donor '21
Any chance it pivots at the point the arm goes into the tank? Disconnect it from the support bracket and pivot it out of the way of the valve cover? Some sort of sleeve. Hard to see that in the picture.
Old Aug 8, 2019 | 07:52 PM
ZeeOSix's Avatar
ZeeOSix
Where the red arrows are, it looks like it might come apart there. GM designers would have to be smoking lots of weed to design it so the engine would have to be removed to take a valve cover off.
Old Aug 8, 2019 | 08:08 PM
ZeeOSix's Avatar
ZeeOSix
Here's a top view. Does look like it bolts to the valve cover. Surely it can be removed to make room to get the valve cover off. I see the same line in the tube. Not hard to make it slide inside itself and use an o-ring to seal it.
To Pull engine to remove passenger side valve cover?
