Spoiler confusion
No spoiler
Low spoiler as part of Z51
High spoiler
As part of the Z51 package, the low spoiler is optimized for higher speed performance
So what is the logic behind the high spoiler?
The Z51 has 2 wings on each side and a spoiler in the middle and is supposed to have 400 pounds of downforce.
The high wing is a pure wing and is supposed to have 500 pounds of downforce.
Both of those numbers are at the highest velocity the car can achieve which is about 184 MPH.
So, at 92 (=184/2) the Z51 wing has 100 pounds of downforce while the High Wing has 125 pounds.
At 61 (=184/3) the Z51 wing has 44 pounds of downforce while the high wing has 55 pounds.
and so on.....
I could only find the file photo of the c5 high wing.
If I read the info correctly, the C8 spoiler creates can create up to 400 lbs of downforce. I have not seen any info on how much downforce the High Wing can create (it's adjustable,, an maybe GM will release at lease Downforce numbers for X number of FT-Pounds at at X number of angles. settings to help owners who plan to tract their cars.)
The car below (a Viper) wing, can create up to 1100 lbs of down force, that slows it Top Speed at the at the Ring to 177 MPH on the straightaway. What time wise on the straight(s)it lost, it more than made up in turns with added grip. It's overall time was better than the Corvette's, but the Corvette had a higher Top Speed. It's on the internet, it must be TRUE... If you noticed it also is running a Spoiler Too.
Picture below is of a Friend's Viper he Tracks (use to Tract Corvettes, but due to blowing LS3 engines due to oil scavenging problems he gave up.
The C8 I'm buying is spec'ed out as a Track Car. My friend (the owner of that Viper) will be the doing Testing after he gets use to the car's manners with both stock tires, and Hoosiers on some of the Tracts he will be competing at, to see how it performs compared to both his Viper, as well as other generation(s) of Corvettes. Why not me? I'll attempt , but it will be a 1st time attempt at it, an I'll be 76 yrs old by the time car is delivered. If there is a class for Geriatrics an I can get a License, I might attempt to learn how to tract it to the Best of my abilities...LOL
No additional spoiler, just a decklid lip. I wonder what that spoiler is actually doing with that wing. If I were to GUESS, and I'm just guessing, it's probably actually hurting his aero not helping because that's a lot of things going on in the back of the car. But only a wind tunnel could tell you that.
The factory spec'ed ACR doesn't have that spoiler which is native to the TA cars. Looks like your buddy had his viper custom built as that wing is definitely not the ACR's wing. Not to say that wing is being improperly used but not the ACR's wing nonetheless. It could be less, could be more too. Here's a factory ACR:
His may be a Carbontech aftermarket one. I know it did not come on car. That's why the spoiler is own it.
How does car perform? Good enough to best a MaClaren by .3th of a second over 7 different track setups. Also in 2018 at the Museum track he was 1st place at one of the sanction shootout there. I'll have to remember to ask him Saturday or Monday if he has any data on it down-force of wing, with or with out the spoiler. I know the Wing did improve his times at same track, but part of that could be learning curve improvement due to seat time.
By the way I thought I saw a picture of C8 doing wind tunnel test with both items on it. May have been a computer wind test simulation program like I saw being used 25 years ago on aircraft designs, were they were trying to cut down on drag yet maintain lift or control of plane.
