Sponsored by: Wheel Design
DCT shift times
Old Nov 27, 2019 | 03:00 PM
Mid8tracker's Avatar
Mid8tracker
Default DCT shift times
How quick are they currently in both auto and manual modes?
Will they improve with more dialed-in programming?
How does it compare to the PDK-S, which is even better than the regular PDK?
PDK-S is used in the GT3/2/RS.
Old Nov 27, 2019 | 03:50 PM
Red Rochester's Avatar
Red Rochester
Veteran: Coast Guard
tell us ?
Old Nov 27, 2019 | 04:30 PM
Mid8tracker
Tell you what?
Old Nov 27, 2019 | 08:52 PM
Red Mist Rulz's Avatar
Red Mist Rulz
GM and Tremec say less than .1 second. (Less than 100 milliseconds.)
Old Nov 27, 2019 | 09:49 PM
Warp Factor's Avatar
Warp Factor
That depends on how you define "shift time". By one measure, it is zero because the shift can take place without any interruption of power to the wheels. But many torque converter automatics can do this too.
Old Nov 28, 2019 | 04:06 AM
New car dude's Avatar
New car dude
We have two or three different takes on DCT, and Edmunds just raved about it. We actually dont know until production starts how it stacks up, but it looks promising.
Old Nov 28, 2019 | 09:11 AM
Tonylmiller's Avatar
Tonylmiller
Mine shifts in . 075 seconds , on average.
Old Nov 28, 2019 | 10:49 AM
rponfick's Avatar
rponfick
I only have a sun dial to measure with, will that work?
Ralph
Old Nov 28, 2019 | 11:31 AM
MitchAlsup's Avatar
MitchAlsup
What I want to know, is:: if I hit the up-flipper 4 times in a single second,
a) will the transmission shift up 4 times in that one second?
b) will the transmission shift up 4 times?
Old Nov 28, 2019 | 11:51 AM
Peppino Esposito's Avatar
Peppino Esposito
These are loaded questions with dual clutch setups. If your car is anticipating upshifts, as it would be if you were on the accelerator pedal, it can theoretically shift 4 times in a second since it is pre-selecting the next higher gear once you request an upshift. However, dual clutch transmissions have this as the worst case scenario: On the accelerator, request an upshift, then immediately request a downshift...all while staying on the accelerator. When this happens, it has already preselected the next gear up, and it has to undo it and select the gear below. This can take some time.
Old Nov 28, 2019 | 11:52 AM
BADBIRDCAGE's Avatar
BADBIRDCAGE
My C6 does.
To DCT shift times
