Sponsored by: Wheel Design
Nav integration...
Old Dec 18, 2019 | 12:45 PM
NavyBlue2's Avatar
NavyBlue2
Default Nav integration...
I'm amazed at all the new technological advancements in the latest C8 , just wondering if GM now finally allow us drivers to fully integrate cell phone technologies onto the Nav screen without purchasing their expensive built in Navigation.
Currently all my vehicles upon startup, recognize via bluetooth my cellphone & music files. It would be wonderful if when I hit the Nav button, it also recognizes that I want to use the always updated Google Map or Wave or whatever future program I set as default map program, instead of factory's built in Nav. All this is auto connected, while phone stays/remains in my cell phone holster on my body (or wife's phone stays in her purse), without us having to physical takes out phone & connect to USB wire, etc.
Both of our kids' latest vehicle purchases demands Apple Play/Android Auto features only & no built-in Nav option. But they still have to plug in a USB wire.
So does today's 2020 & beyond vehicles offer same technology via bluetooth, without physical wire connection?
Thanks,
Old Dec 18, 2019 | 12:57 PM
MoveOver's Avatar
MoveOver
Wire required for Apple Play/Android Auto for all packages. Some features like PDR and Front lift do require build in NAV so 2LT and 3LT also have build-in NAV besides the Apple Play/Android Auto.
Old Dec 18, 2019 | 02:45 PM
Jeff V.'s Avatar
Jeff V.
Is it documented that the front end lift requires navigation? Even without navigation, the car still has OnStar. OnStar has its own GPS capabilities.
Old Dec 18, 2019 | 02:56 PM
Modshack's Avatar
Modshack
Thanks,
The (unreleased) 2020 Trailblazer offers Wireless Carplay, so we can only assume it will be somewhere in the future
Old Dec 18, 2019 | 03:01 PM
Zymurgy's Avatar
Zymurgy
Moderator
Front lift is only available on 2LT and 3LT, both of which have Nav standard.
Old Dec 18, 2019 | 03:07 PM
RKCRLR's Avatar
RKCRLR
I don't know if it is documented but that is the assumption. It isn't available on the 1LT which doesn't have nav but is available on the 2LT & 3LTs which does have nav. My suspicion is the lift is designed to work with the nav system built into the infotainment system. Or it could just be marketing...
Old Dec 18, 2019 | 03:21 PM
george vee's Avatar
george vee
2015 C7 of the Year Finalist
Cell phone navigation is great but when you loose service the factory nav will get you there
Old Dec 18, 2019 | 03:32 PM
Ragtop 99's Avatar
Ragtop 99
Cell phone nav can work without a cell signal.
I drove all over Iceland with a pre-loaded google maps and no cell service. Typically, I would load the destination while I had wifi since the preloaded maps don't have the same level of detail for restaurants, hotels, and smaller attractions.
Old Dec 18, 2019 | 03:56 PM
MoveOver's Avatar
MoveOver
Depends on the App you use. Here WeGo uses maps and your cell's GPS signal to navigate and includes all maps for free including overseas. It operates just like you Garmin and TomTom, It used to be the old Nokia Nav system and now owned by the German Car mfg's. https://www.here.com/
Old Dec 18, 2019 | 04:38 PM
NavyBlue2's Avatar
NavyBlue2
My current factory extended warranty goes to 2023, so hopefully wireless CarPlay/AA feature will be available by then.
Also, look for integrated wireless charging pad, without wires...
Old Dec 18, 2019 | 07:53 PM
MoveOver's Avatar
MoveOver
2LT/3LT Packages do include wireless charging but at this time no wireless CarPlay/AA
Old Dec 18, 2019 | 08:00 PM
johnodrake's Avatar
johnodrake
Moderator
My guess is the OEM nav will have a more detailed and crisp screen than CarPlay. The wife’s Mercedes has Nav and CarPlay. CarPlay maps look like mud in comparison to thr native nav.
Old Dec 18, 2019 | 10:22 PM
Red Mist Rulz's Avatar
Red Mist Rulz
No. OnStar uses the GPS receiver in the car to tell where you are. How else could it work?
Old Dec 18, 2019 | 10:24 PM
Red Mist Rulz
The ability to memorize places where you want lift, so the car raises the front end automatically, requires Nav. How else would it know where the car is and when to raise the front end?
MANUALLY lifting the front end wouldn't actually require Nav, but GM chose not to offer that option.
Old Dec 18, 2019 | 10:27 PM
Bob Paris's Avatar
Bob Paris
I don't look at the map since I am driving. I only want directions and Carplay, since it offers live traffic, is fantastic. I have a hunch that most would agree.
Old Dec 18, 2019 | 10:29 PM
Red Mist Rulz
Wireless CarPlay or Android Auto requires the car's display system to use WiFi, not just Bluetooth. BT doesn't have enough bandwidth to support real time map updating. So the current hardware can't support wireless via just a software update.
The other downside to wireless AA / CP is that it sucks battery like there's no tomorrow, so you need to be charging at the same time. And wireless charging and navigation at the same time will really heat up the phone and battery.
It's really not THAT hard to plug your phone in when you need maps.
Old Dec 19, 2019 | 07:14 AM
MoveOver's Avatar
MoveOver
For that reason they cool the phone cradle area.
Old Dec 19, 2019 | 09:39 AM
Jeff V.'s Avatar
Jeff V.
As I said, OnStar has GPS capability even without the navigation option. On the C7, the OnStar module broadcasts the car's GPS location over the data bus, regardless of whether you have navigation or not. It'd be trivial to have the front end lift control module listen for that message and act accordingly.
Now whether or not GM set it up to work that way is a whole other question. It depends on how much of the software functionality is in the lift control module vs the infotainment module. But it's at least possible.
Old Dec 19, 2019 | 09:46 AM
Dan Delena's Avatar
Dan Delena
possibly a bit of semantics, however I think what is needed for the “Lift” function is a GPS location, which is different than the Nav system, which also needs a GPS signal. I assume if 1LT cars have OnStar, they have GPS capability for that function, and that alone could be sufficient to provide the location in support of the Lift system. It might be marketing to link the Lift and 2LT+ levels of trim, but simple GPS is all the Lift needs.
Relative to this thread I generally use Waze and with CarPlay it integrates into the audio system so looking at the map isn’t a hard requirement and the Waze maps show on the video head unit and are more than good enough to show turns and of course traffic and PoPo reports. Since it uses the GPS of the phone, cell service is less of an issue. The caveat is that active Waze maps require a data signal (cellular) even if the car has wifi so in remote areas the loaded maps in the C8 will be a good backup.
To Nav integration...
