Sponsored by: Wheel Design
Cabin air filter
Old Feb 2, 2020 | 01:19 PM
prodriver's Avatar
prodriver
Default Cabin air filter C8?
Do you guys know if there is a Cabin air filter installed on the C8, if so where is the filter location? Ease of service?
Old Feb 2, 2020 | 02:12 PM
BIG Dave's Avatar
BIG Dave
There is one in the C7, can’t see why they would have done away with it for the C8. For the C7, you access it from under the (front) hood, and it slides in through the firewall, near the top on the passenger side.
Old Feb 2, 2020 | 03:20 PM
Red Mist Rulz's Avatar
Red Mist Rulz
My guess it that it's behind the frunk, under the same panels that come off to reveal the battery.
You can see in air intake next to the battery in this image. And I'll guess the filter is under that flat cover just behind it.
Old Feb 3, 2020 | 05:46 AM
MikeyTX's Avatar
MikeyTX
Veteran: Marine Corps
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
Yup, just under that opening that I've named "Kathryn", in honor of my ex wife is the CAF. There is a pic of it in one of the early threads that shows the front compartment with the vanity liner removed. It is very similar in size/shape to the C7. Would not be surprised to find it uses the same p/n.
Old Feb 3, 2020 | 09:30 AM
Peppino Esposito's Avatar
Peppino Esposito
sure does look like it's under that cover.
Old Jan 27, 2022 | 02:17 PM
VonVette's Avatar
VonVette
1st Gear
Yes, the cabin filter is located behind that cover that is next to the air intake and battery in the photo above. Here is a YouTube video on how to change it
Old Jan 27, 2022 | 02:30 PM
Kracka's Avatar
Kracka
Easy swap; I live in a dusty construction zone (new development) and swapped out the factory one for something better (Fram FreshBreeze) early on.
Old Jan 27, 2022 | 02:45 PM
johnodrake's Avatar
johnodrake
Moderator
Looks like a good filter - until I discovered it was made in China. I wonder if there are any good filters made other than in China?
Old Jan 27, 2022 | 02:47 PM
Zymurgy's Avatar
Zymurgy
Moderator
GM part number 13508023
Old Jan 27, 2022 | 02:54 PM
Kracka's Avatar
Kracka
The Fram FreshBreeze is about as good as you'll get as far as cabin air filters go. You can get the Bosch HEPA (also made in China) but that severely cuts airflow/efficiency. The Champion Labs/Luber-Finer carbon ones are pretty nice too. TYC carbons (China) are ok. The standard ACDelcos (various... China, Germany, USA, etc.) are nothing special while their carbon ones (China) are above average. You're going to have a hard time finding a cabin air filter that isn't made overseas in Asia somewhere.
Found you one! The ACDelco CF185 has USA as the country of origin
$14.02 from RockAuto. OEM filter, nothing fancy.
Found you another one! Fram TrueAir CV11966 which apparently uses N95 material.
$19.97 at Walmart.
Old Jan 27, 2022 | 03:36 PM
Red Mist Rulz
Driving an HTC with the top down whenever I can, I feel like it doesn't matter too much what cabin filter I use.....
Old Jan 27, 2022 | 04:10 PM
jimjimsC7's Avatar
jimjimsC7
Good point!
Old Jan 27, 2022 | 05:05 PM
srosenbldr's Avatar
srosenbldr
Just wear an N95!
Old Jan 27, 2022 | 07:42 PM
BIG Dave's Avatar
BIG Dave
Says “MADE IN USA WITH FOREIGN MATERIALS” in the video from Post #6. Where are you seeing it’s made in China?
(Screenshot inverted for clarity).
Old Jan 27, 2022 | 08:31 PM
Kracka's Avatar
Kracka
He was referring to the Frame FreshBreeze that I installed.
Old Jan 28, 2022 | 11:15 AM
papillion's Avatar
papillion
Default Clean Air I Guess
I still have our C6 replacement air filter in the garage. Never installed it. Kept it when I read it would fit our C7. Which is also gone away. I doubt I'll find out, but it might fit the C8? Why reinvent a humble part like this when an off the shelf piece would work?
Old Jan 28, 2022 | 11:25 AM
johnodrake's Avatar
johnodrake
Moderator
Yes. Looked on Amazon site. Information shows made in China as country of origin
To Cabin air filter
Old Jan 28, 2022 | 11:27 AM
johnodrake's Avatar
johnodrake
Moderator
$19.97 at Walmart.
Thanks, I was expecting none!
Old Jan 28, 2022 | 01:34 PM
Kracka's Avatar
Kracka
Neither was I! With this new info in mind, I think I'll be trying that Fram TrueAir next because the OEM ACDelco ones are Kleenex thin junk.
Old Jan 28, 2022 | 01:35 PM
Kracka's Avatar
Kracka
C6 & C7 shared, but the C8 is a different size that's now shared on many newer vehicles across the GM fleet.
