Performance Traction Management
With C7 you had to have MSRC to have PTM. Is the same true on C8? If so, it's probably similar to the default Track mode on non-MSRC C7s, whatever that is.
Basically, all you have is a stiffer suspension and stiffer steering but the nannies are on and there is no PTM.
The C8 OM should have a similar description. I have the impression the C8 OM is like the C7 OM and drivers will have to memorize the driving parts of the OM to be able to make full use of the car's potential.
Bill
I wonder why they did it this way. Is it an oversight? It doesn't seem that technically challenging to be allow it to be directly linked. Or perhaps the lawyers didn't like it. They probably don't like that a Track mode even exists.
Without the comparable C8 PTM chart, we don't know exactly how it's set up.
Even in regular Track mode, to get to PTM Race it takes 2 button presses and 4 turns of the dial on a C7.
- First, just putting it in Track mode, the Traction Management ("TM"), is too invasive, and the car is undrivable on the track.
- Setting the PTM to "Race" removes the TM, but, depending on your tires, and the track conditions, the car is difficult to control on corner exit, as the torque can break the rear tires lose very quickly.... the MPSS tires, are very temp-sensitive and unpredictable.... its a "spin in s box".
- Setting the PTM to "Race" mode does not disable the yaw control, and going around the "lightbulb" turn at NJMP, and powering on as I usually do, the left-rear brake burned through a brand-new set of track pads, and scored the rotor in 20 minutes....... I asked this question 100 times on this site and nobody can explain the relationship between PTM "Race" mode, and Yaw but a scored rotor answered the question... it still activates, and you don't want that on the track.
- Now, with a set of MPSC2, I set the car to PTM in Sport 2, and that is a good compromise.... the back end can still kick out, but it keeps the car under reasonable control. So that's the best setting I can suggest unless you do a full race setup with race tires.
I would assume that putting the car in track mode and not entering PTM the car will default to the most conservative setting? It'd be a good question Ask Tadge.
My plan is to setup MyMode for my preferred commute, Z mode for fun curvy roads, and then when I'm on track I'll use track mode PTM Race.
Sure there is Weather mode too, but that just makes the car feel dead.
Note: If PTM is set to anything other than Wet in Z-Mode, the Suspension automatically is set to Track/all the way to the right. If you try to change suspension to Sport/midpoint PTM is disabled in Z-Mode.
- The 2021 Owners manual: Wet, Dry, Sport 1, Sport 2 and Race.
- The 2022 Owners manual: Off, Wet, Dry, Sport, Race 1 and Race 2.
This must be a warning required by the lawyers as PTM does stay in Sport/as configured previously after a vehicle restart.
Robert MacCready posted this great video back in June on this topic:
