Sponsored by: Wheel Design
Front lift
Old Mar 23, 2020 | 01:32 PM
C8-Vette's Avatar
C8-Vette
Default Front lift
Where on the steering is the symbol or control to set the ride lift. I read the manual ,its useless for this item. A "check mark' is indicated to set the lift, but cant find this mark anywhere.
Old Mar 23, 2020 | 01:39 PM
Trustym's Avatar
Trustym
Front lift button is on center console. If you mean to set the memory, it should ask if want to save location each time used.
Old Mar 23, 2020 | 01:43 PM
Bikerjulio's Avatar
Bikerjulio
I had the exact same complaint. Push the start button without brake in order to get to ACC mode and the same "check mark" instruction comes up.
Turns out it's asking for a push of the thumbwheel on the steering wheel that is really an "OK" or "SET" indication to the car.
Old Mar 23, 2020 | 01:46 PM
Trustym's Avatar
Trustym
Found this in manual as well.
Old Mar 23, 2020 | 01:49 PM
ufaj26's Avatar
ufaj26
Default lift
Its the middle button just in front. When you activate the button it asks if you want to save the location. If so you hit "<" symbol and it save that location
Old Mar 23, 2020 | 01:50 PM
C8-Vette's Avatar
C8-Vette
Just roll the wheel-----------up /down , does it make a difference? Where the hell in the manual does it tell you this? I am going to try it as soon as it stops raining. Thanks for the response,
edit PUSH the wheel, not roll it
Old Mar 23, 2020 | 07:40 PM
ufaj26's Avatar
ufaj26
This < symbol is just to the left of the push/roll button
Push and release the lift button and for a moment or two the screen will display asking you to press the < symbol if you want to remember this area. Once you do hit the < symbol the screen will indicate that it is saved.
Old Mar 24, 2020 | 07:09 AM
C8-Vette's Avatar
C8-Vette
The symbol on the dash is a "check mark" not a < thats whats confusing
To Front lift
