Sponsored by: Wheel Design
Transmission failure
Old Mar 28, 2020 | 08:44 PM
rmorin1249's Avatar
rmorin1249
St. Jude Donor '15-'16,'18
Default Transmission failure
Hopefully this is a one off: https://carbuzz.com/news/2020-c8-cor...after-32-miles
Old Mar 28, 2020 | 08:48 PM
24/Eray's Avatar
24/Eray
Normal type of failure. Hiw many parts are in there? They always calculate a failure rate. With 3k built or so CTF and production? I'm thinking you would need to see maybe 30+ trans have to be swapped before they even blink
Old Mar 28, 2020 | 09:01 PM
JoelVetteguy's Avatar
JoelVetteguy
It was an oil leak. No mechanical failure. Most likely bad seal. Happens. Stinks but happens. No big deal.
Old Mar 28, 2020 | 09:41 PM
Steve Garrett's Avatar
Steve Garrett
CORVETTE TODAY Show Host
CORVETTE TODAY Host
St. Jude Donor'15
Agreed...gotta be a one-off situation.
Old Mar 28, 2020 | 09:58 PM
rramjet's Avatar
rramjet
The 8 speed in my 2015 quit at 79 miles. Wouldn’t go into any gear. Got the car back in 4 work days. GM had one overnighted to the dealer.
Old Mar 28, 2020 | 10:06 PM
d96eddie2's Avatar
d96eddie2
Agree fully, "Transmission failure" this is not. Transmission filter fluid leaks are well known. Others perhaps. For now this "Transmission failure" is a non issue.
Michael
Old Mar 28, 2020 | 10:45 PM
starscream716's Avatar
starscream716
It was just a leaky axle seal, that’s all. Covered in another thread on this board days ago.
Old Mar 29, 2020 | 02:22 PM
Larry/car's Avatar
Larry/car
After all the automatic transmission failures and having owned a 2016 Colorado I will never own a GM automatic again. No C8 for me.
Old Mar 29, 2020 | 02:25 PM
rmorin1249's Avatar
rmorin1249
I have similar feelings after the experience I had with my '16 Stingray. I'm waiting a couple years before considering a C8.
Old Mar 30, 2020 | 07:15 AM
baf2000_1's Avatar
baf2000_1
Though this looks like it is not a mechanical failure of the trans, it could very well be a faulty seal.
If so could be a failure that needs to be fixed on many cars.
The first year of a new DCT could be a tough one. Performance drivers beware
Old Mar 30, 2020 | 09:10 AM
Tonylmiller's Avatar
Tonylmiller
Should have gone with the manual transmission and this would not have happened!!!!!!!!!!!!!!!111
I have heard that this thing has TWO CLUTCHES!!!!!1 A person only has two feet, how are we supposed to drive that?!?!?!?!?!?!?!?!
Old Mar 30, 2020 | 09:23 AM
CamsC8's Avatar
CamsC8
Guys...do you realize how many PDK failures occured and still occur in Porsche circles. Chill.
And that's the benchmark dual clutch on the market.
Old Mar 30, 2020 | 09:38 AM
C8Jake's Avatar
C8Jake
that's relevant
Old Mar 30, 2020 | 09:42 AM
CamsC8's Avatar
CamsC8
Originally Posted by C8Jake
that's relevant
It is relevant. Do you honestly think manufacturers come out with perfect transmissions each and every time? Porsche are way more detail and engineering orientated and they still have their issues.
Yes this is relevant. Hell Porsche even had engine failures in the 14/15 GT3s and God forbid GM has a tranny leak... imagine engine failures on the C8..."ahhh sky is falling".
Old Mar 30, 2020 | 09:46 AM
24/Eray's Avatar
24/Eray
theres pros and cons to being first to have a product. I applaud those willing (I am no longer one) because without those brave enough? We wouldn't have new models lol.
C8Jake's Avatar
C8Jake
Porsche are way more detail and engineering orientated.
of course
Old Mar 30, 2020 | 01:11 PM
7thgeneration's Avatar
7thgeneration
Of course transmission failure sounds much more dramatic than a simple fluid leak. Oh my God what will we all do, what will we all do ?
To Transmission failure
Old Mar 30, 2020 | 01:25 PM
edgenet1's Avatar
edgenet1
Too bad GM did not choose to go with a bullet-proof ZF tranny. Nowadays the Trannies are far more complex than any engine especially the GM push-rod engines created in the 30's
Old Mar 30, 2020 | 01:28 PM
edgenet1's Avatar
edgenet1
Are you kidding a seal bet all made in China
Old Mar 30, 2020 | 02:13 PM
rangda's Avatar
rangda
That is why it is called a dual clutch transmission. A dual clutch transmission is sort of like combining two manual gearboxes, one that handles all the odd gears and one that handles all the even gears. Each virtual gearbox has its own clutch. That is how the shifts are so fast, you are always shifting sequentially so when you go up or down a gear you are really hopping between transmissions, with the help of electronics. Which is also why the qualify of the programming of said electronics can make or break the responsiveness and performance of a dual clutch. When shifting gears software handles clutch in/out for you which is why there is no clutch pedal even though the transmission is effectively working like a manual (you could never work the pedal fast enough anyway). My explanation is overly simplified, here is a more detailed look at what goes on:
https://auto.howstuffworks.com/dual-...ansmission.htm
This tech is not new, it's been in racing and other performance cars for decades. The specific gearbox in the C8, however, is new, and some teething problems should be expected.
