Sponsored by: Wheel Design
Random Nav problem
Old Apr 6, 2020 | 05:38 PM
Ed Biancarelli's Avatar
Ed Biancarelli
Default Random Nav problem
I have gotten this message randomly on my system. Anyone else seen this? Re-inserting SD card does not fix. I have it return to normal at various times.
Old Apr 7, 2020 | 12:12 PM
kong's Avatar
kong
I assume you formatted it correctly?
Old Apr 7, 2020 | 12:25 PM
Grumps' Garage's Avatar
Grumps' Garage
I don't think you are supposed to format the NAV sd card. It comes with the car from GM.
Old Apr 7, 2020 | 12:35 PM
CitznFish's Avatar
CitznFish
maybe a loose connection inside the unit that gets jarred from time to time? Let us know if you take it to a dealer and what they say
Old Apr 7, 2020 | 12:49 PM
Modshack's Avatar
Modshack
Did you look in the center console? The card is there right next to the usb plug... (unseated? Missing?)
Old Apr 7, 2020 | 02:04 PM
Ed Biancarelli
Default Dealer diagnosis
Took it in and based on the code (40000.0112) it is either the card reader unit or the display unit (yikes)! They are ordering the reader unit that is in the armrest console. Don’t know how soon that will come in.
Old Apr 7, 2020 | 10:17 PM
Michael A's Avatar
Michael A
Thanks for the update. Let us know how it turns out.
Old Apr 7, 2020 | 11:25 PM
24/Eray's Avatar
24/Eray
My bet is a corrupt SD card.
Had this in my kid's 18 Terrain (has the same 3.0 or whatever version the C8 has).
They ordered me a new card because they tried to install an SD card off of a stock unit and it was actually mated to the car itself.
Worked for 50 miles then displayed that same message again.
Good luck. Probably just sd card.
Old Apr 14, 2020 | 12:34 PM
Ed Biancarelli
Still waiting on a call from dealer with the new part (SD reader), but the damn thing has been working great since.
Old Apr 14, 2020 | 01:53 PM
johnodrake's Avatar
johnodrake
Moderator
I assume that if you used Car Play that wouldn't appear.
Old Apr 14, 2020 | 03:46 PM
24/Eray's Avatar
24/Eray
I think on my wife's gmc the message came up once the infotainment system booted? But it should be a simple fix if not the card it'll be card reader. If only every issue with a Corvette were this trivial lol
Old Aug 2, 2020 | 01:58 PM
Yrret Eiryam's Avatar
Yrret Eiryam
1st Gear
Yesterday I received a similar error code. Did the dealer fix the issue? What was done? Thanks
Old Aug 2, 2020 | 02:49 PM
Ed Biancarelli
I never had the error again, so I elected not to have them replace the reader unit. Try cleaning contacts on SD card and re-insert.
To Random Nav problem
