I’m having trouble with the new PDR, there should be a database of tracks but mine us empty. Also can’t figure out how to do a custom track. There is a relearn feature, and not sure why you would need this. Any info would be helpful.
Short answer. The tracks are not in the database at this time. They are working on it.
The relearn was a poor choice of words. Once you learn the 1st track any tracks after that are a relearn.
thanx. Very helpful.
the other thing I figured out is that if you make a custom track it won’t be listed as a saved track, unless you rename it, and to do that you have to take the data card out and rename it on a computer. Seems crazy unless I’m missing something.
St. Jude Donor 05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
I don't believe that is true. It saves my custom tracks with no rename. Stay at it, you are getting close.
so I’m gonna double down and again say there is no easy was to save a custom track. When you create one there is no way to rename it. The default name is custom. I created 3 different tracks during one drive, and when I look at the card it only saves the latest one with the custom name. Now, if I rename the card on my computer it then shows up as a saved track. If there is a way to name and save a custom track, I can’t figure out what that method is.
