Paint issue
wonder if jams are getting prepped correctly - does seem to appear the paint jams may not be getting loving - probably not getting a good enough prep on the tough to get at areas (jams) you know what I meanJust take a look at under the C7 hood what a joke
While I'm at it look at GM Truck in silver - paint does not do this - paint lay down (metallic) looks superb and the paint is not falling off - also silver base on the C7 on the other hand was a joke
These cars just fall apart from a body panel/fitment/paint perspective as well as interior squeaks, rattles, and other annoying buzzing noises.
The problem with Corvette fit and finish be it the panel gaps or be it the paint issues in the corners or be it the interior noises comes from one and one simple fact (even the QC issues all result from the same issue):
- The multi panel, modular, body on frame architecture which means you have an aluminum base, and some molded plastic semi body on it, which then has lots of individual plastic panels being attached using dozens if not hundreds of torx bolts. This architecture is RECIPE FOR DISASTER. This is the problem of Corvette.
There is no way to QC these cars. I ask you watch how these cars are built. This car is essentially built like a wooden house. The concrete foundation, brick walls, then wood frame, then siding, then roof. When you build a sports car like this, it is likely that something will go wrong. It is likely the car will rattle.
Compare this to say a Porsche or Audi or BMW or even Mustang, they are all aluminum welded one big body. Their A/B/C pillar is one piece all welded to the undercarriage. This removes so much QC issues before they happen.
They know nothing about building cars, but you sure do.
It has nothing to do with what GM knows vs what the poster you are referring to does. He's pointing out how they took a shortcut on the car which is what is leading to some of the issues. Just because he doesn't work at GM doesn't mean he doesn't know the inter workings of how a car is built.
Blaming the Accountant for production mistakes is like blaming the score keeper for why the Yankees lost the World Series.
Maybe your aren’t aware, automobile companies that are not profitable eventually go bankrupt. Engineers and operators managers make the bad choices.
It's a Chevy and they have an acceptable target... "good enough, most of the time".
Disagree here... the whole reason they moved to the skillet system was so they'd be assembling the body on a loaded chassis.
For Corvettes? Look at the performance for the buck? Nothing comes close. And they sell every one they make. Always have.. probably always will. I am as guilty as the next. I buy them. I also buy GM. When wife's lease goes back I am going to another mfr and try one out. Maybe I need a reality check that the grass isn't greener? Or I'll be kicking myself for not leaving sooner.
My wife drives Mercedes and won't consider anything else. The service experience is excellent and they're very very very safe. My mother was rear-ended while stopped with a 50 mph speed delta in her 2008 CLS550 and walked away. Another friend rolled his GLS on the highway (not his fault) and whole family walked away.
I believe that once you're spending more than $60k on a vehicle, you should receive maintenance and a loaner vehicle. Rather annoying to be hit up for a maintenance plan. Also, the warranties on the foreign cars tend to be longer, at 5yrs versus 3 or 2 yrs with others. Just my thoughts.
