Sponsored by: Wheel Design
Ground Effects 5VM Question ?????
Old Aug 4, 2020 | 09:29 PM
HARVEY T.GLUCK's Avatar
HARVEY T.GLUCK
Default Ground Effects 5VM Question ?????
Was Wondering can you remove the GM installed (by Dealer) Ground Effects and Install them on another Corvette (ie Convertible)-assuming you have the original ground effects that came with the Corvette—-Do not think there was a Front Splitter from the Factory.....
Mine do show on the Window Sticker—think it was $4600.00............Thanks in advance......H
Old Aug 4, 2020 | 09:32 PM
Strake's Avatar
Strake
2020 C8 of the Year Finalist - Unmodified
Harvey,
Keep in mind, that although you should be able to remove and install on another C8, it will leave 2 fairly large holes drilled through the side of the painted rear quarter panel where the turned up wing is. There will be one hole on each side of the car. Also, on the underneath side of the rocker panels, not in view will also be another 6 holes per side where the rivets are that hold on the side skirt.
Old Aug 4, 2020 | 09:38 PM
HARVEY T.GLUCK
thats what I thought..........
To Ground Effects 5VM Question ?????
