Went to pick up some options at My dealer ,to startup the ordering process for 2021 HTC C8. , I like to get the microfiber for interior Red. , does anyone have experience with microfiber upkeep in a car , is it easy to clean ? since the material is used in areas where it comes in contact ,thanx for any advise in advance.
My 2014 has the microfiber interior (also called sueded microfiber). I love it. My C8 that has a 8/31 TPW has it as well.It is very easy to maintain and keeps your butt from sliding around. Sonax makes a great microfiber cleaner.
I think he is referring to the interior trim in microfiber (suede) yes???
Its synthetic and treated with stain resistance, should be easy to clean with little to no detergents. Warm water and a mild detergent for anything less than a dye stain.
I had a Viper for 3 years some time ago and it had the 'micro-fiber' seat inserts. (My wife referred to it as 'velcro'). Wear and cleaning was a non-issue. We don't own any jeans so you should take that into consideration with color transfer. The good news is you are held in place during spirited driving. The bad news is you don't easily slide in and out of the seat when you go to Starbucks....
2LT suede seat inserts require a suede steering wheel. 3LT gives you the suede seat inserts requires suede steering wheel as well and gives you suede A-Pillars and roof plus a suede front console on dipped colors.
I first got suede inserts in our 2012 Camaro ZL1 and ordered them in our 2015 Corvette. I also put them in our custom 67 Vette seats. I really like them. Never too hot or too cold. They hold you in place and you will not slide around. The upkeep is very easy. But there are a lot of people that do not like it, a matter of personal preference.
I like to Thank you for all the responses very Helpful I will choose microfiber after reading the responses. let me share with you what am going to get in 2021 Hard Top Convertable
2LT Red with Two-Tone microfiber interior, GT 2 Seats, black roof, and nacelles Red Calipers, front lift depending on functionality may the Mag Ride, as well There is a new Color called Red Mist metallic for 2021 which is an option to consider am not sure of Carbon Trim for interior yet.
when I was at the dealer picking the initial options just to get into the system we could not find the microfiber trim for the Dashboard area and interior door panels does anyone know if that is offered?
please add any comments regarding the above
I have difficulty seeing the Matrix you posted, if possible can you send me a link, it may have info as to microfiber availability for the door panels and for dashboard surfaces
Thankx in advance
Thankx in advance
Not true. I went thru this when I ordered my suede steering wheel. There are 2 options for the suede seat inserts. One that does not allow the suede steering wheel and the other that does. Both have the same description so it’s not obvious.
