Sponsored by: Wheel Design
Help, engine blew on track.
Old Aug 29, 2020 | 05:35 PM
Egoncool's Avatar
Egoncool
Default Help, engine blew on track.
So I’m at the track, VIR, and my engine just blew at the top of the backstretch when I went wot. Does anyone know how to shift the car into neutral without starting the engine?
Popular Reply
Aug 29, 2020, 08:47 PM
Egoncool's Avatar
Egoncool
Originally Posted by 19/C7Z
Looking at the OP post history he uses the car as it was designed (allegedly). But it hasn't been kind to him for it.
I mean... he had all kinds of issues. Electrical. Trans. Now this?
Might be better starting over again.
Feels like his Porsche put the horns on that C8.
Im surprised you don’t have my second grade report card listed.
You know I have had issues, but until now they were minor. Even today after the engine went, people were coming up to me, and I was singing the virtues of the car. It is the best car I’ve ever owned, and I’m a Porsche guy, not a Corvette fan boy. This happens at tracks all too often, with all, makes of cars. It was a surreal experience, and I’m still coming to terms with it, but I wasn’t hurt, and the car will be fixed and life goes on.
Old Aug 29, 2020 | 05:38 PM
Patriot10's Avatar
Patriot10
Sorry to hear this.
Old Aug 29, 2020 | 05:43 PM
bad mooofooo's Avatar
bad mooofooo
Modified C8 of the Year 2021 Finalist
Old Aug 29, 2020 | 05:51 PM
Red Mist Rulz's Avatar
Red Mist Rulz
Is the car in Park, or still in gear? If not in Park, try pushing the start button for 8 seconds or so without your foot on the brake. That should put the car in "On" position. Then try pushing the N button. But based on the quoted text below, it sounds like that won't work.
The only other way I'm aware of is a special tool ("Park Release Tool") GM sells that fits into the top (or is it the bottom? - I think it's the top) of the transaxle.
Manually Shifting to Neutral
With the ETRS system, the transmission parking pawl cannot be disengaged unless the engine is running. If there is a loss of vehicle battery power, the DT-52388 manual park release tool can be used to shift the transmission to Neutral and move the vehicle. Due to spring pressure, the tool must be applied to the release lever and held in the release position while moving the vehicle. The manual park release is located on the right side of the transmission and can be accessed through the trunk.
https://gm-techlink.com/?p=12881
Old Aug 29, 2020 | 06:18 PM
4XLR8N's Avatar
4XLR8N
Pro Mechanic
Funny how modern technology has made the simple things so difficult.
Sorry to hear about you engine...what happened?
Old Aug 29, 2020 | 06:22 PM
24/Eray's Avatar
24/Eray
Default Earlier Vin iirc?
Well. Someone was gonna be the first test cade for gm covering track use under warranty.
The OP posts alot of his 718 and his track use. Sucks that someone like him had this happen. Vs the one that will sit in the garage 28 days a month and never brought over 3k rpm.
Good luck OP. Hope it works out in your favor somehow.
Old Aug 29, 2020 | 06:46 PM
Egoncool's Avatar
Egoncool
well I thought the Porsche was retired, but I’m supposed to go to Watkins Glen next week so I guess just when it thought it was out, they pull it back in.
Old Aug 29, 2020 | 06:59 PM
OnPoint's Avatar
OnPoint
The Consigliere
OP - sorry to hear. Any warnings (engine sound, gauges, lights, etc)?
Good luck with the repair. GM has been pretty decent with warranting for track use; hopefully they'll do so with yours.
Old Aug 29, 2020 | 07:00 PM
HKH's Avatar
HKH
How do you put a Corvette in neutral with a dead battery?
How Was The 2020 C8 Corvette Designed?
You need to get the car into service mode:
  1. Foot OFF the brake.
  2. Press and HOLD Start button for ~8-10 seconds.
  3. Lights and chimes will sound and it will be just like the "old days" of key two clicks. ...
  4. Release Start button.
  5. Press brake and shift into Neutral.
More items...
Dec 18, 2016
Old Aug 29, 2020 | 07:11 PM
Egoncool's Avatar
Egoncool
a bang and a sickening grinding sound and then no power and zero engine oil alert. I have what looks like a piece of the crankcase. Oil all over the track, all happened in a few seconds,
Old Aug 29, 2020 | 07:18 PM
BlaznZ06's Avatar
BlaznZ06
I had this happen with a C6 Z06 when they were only out for a few months. It was horrible limping off the track.
Old Aug 29, 2020 | 07:49 PM
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
Good luck on the warranty if they find it was your fault.
When I worked for Ford Mustang Cobra came and went through our shop trying to tell us mechanical failure of the engine, and Ford thought otherwise.
Old Aug 29, 2020 | 07:57 PM
24/Eray's Avatar
24/Eray
they'll cover it.
This car is new and hot and they don't want publicity in the negative ESPECIALLY on the track.
I'm sure they'll be anxious to get that engine back to the team so the engineers can tear it down. The instructions will be take it out wrap it crate it we'll pick it up tomorrow.
Old Aug 29, 2020 | 08:00 PM
Broken Halo's Avatar
Broken Halo
DT-52388 Manual Park Release Tool $595.03
https://www.freedomracing.com/dt-523...ease-tool.html
Old Aug 29, 2020 | 08:10 PM
blackmagicZ's Avatar
blackmagicZ
Curious, how many miles on it?
stormcloak's Avatar
stormcloak
This is a bummer to have happen. Hope you're back up and running soon!
Old Aug 29, 2020 | 08:16 PM
Egoncool's Avatar
Egoncool
Originally Posted by blackmagicz
curious, how many miles on it?
4800 and it wasn’t tracked until it had over 1500 miles on it. I followed all their recommendations.
To Help, engine blew on track.
Old Aug 29, 2020 | 08:17 PM
24/Eray's Avatar
24/Eray
Default sometimes you just get a Lemon.
heisnuts's Avatar
heisnuts
Assuming it has the Z51 package and over 500 miles, I cannot see why they would question warranty. I hope all goes well and you are back on the road/track again soon.
Old Aug 29, 2020 | 08:31 PM
MagicGlass's Avatar
MagicGlass
Ooh Geeze I think I want my $1000 back. Its only $60K well I guess we are getting what we pay for.
