Sponsored by: Wheel Design
Bump Start?
Old Sep 16, 2020 | 02:23 PM
bimmerborn's Avatar
bimmerborn
Default Bump Start?
Can one bump start C8?
** Honest question. In theory, ignition can be turned on by pushing the start button and foot off the brakes. Then if the car goes in D or R, one can pull both paddles for neutral can get the car rolling in a slope. Then releasing the paddles will engage the clutch and turns the engine. OP assumes all clutch and gear functions of the transmission is controlled via electric solenoids Vs hydraulic pumps.
*** Not recommended to test on a car equipped with brake by wire system.
Old Sep 16, 2020 | 02:46 PM
SonicRaT's Avatar
SonicRaT
I didn't think it was possible to shift out of park if the car wasn't running -- isn't that what that expensive DCT is for that allows to disengage the parking brake on cars that don't start?
Old Sep 16, 2020 | 02:48 PM
919cw313's Avatar
919cw313
2018 C6 of Year Finalist
You should try it.
Old Sep 16, 2020 | 02:52 PM
jimmyb's Avatar
jimmyb
Really?
I think you can (bump start) a C8 if you squirt a little starter fluid in the carb...
What is this...1968?
Old Sep 16, 2020 | 03:25 PM
Racer X's Avatar
Racer X
Originally Posted by jimmyb
Really?
It is a legitimate question. People's batteries go flat even in 2020. The question is it more like a manual or a torque converter automatic?
Old Sep 16, 2020 | 03:30 PM
Newdude's Avatar
Newdude
Uh no. You can't bump start. DCT would be treated like an automatic transmission vehicle.
Old Sep 16, 2020 | 06:35 PM
Red Mist Rulz's Avatar
Red Mist Rulz
It's not possible to shift the DCT out of park if the engine is not running. Carry jumper cables.
https://gm-techlink.com/?p=12881
Manually Shifting to Neutral
With the ETRS system, the transmission parking pawl cannot be disengaged unless the engine is running. If there is a loss of vehicle battery power, the DT-52388 manual park release tool can be used to shift the transmission to Neutral and move the vehicle. Due to spring pressure, the tool must be applied to the release lever and held in the release position while moving the vehicle. The manual park release is located on the right side of the transmission and can be accessed through the trunk.
Old Sep 16, 2020 | 07:38 PM
MY03C5Z's Avatar
MY03C5Z
Old Sep 16, 2020 | 09:31 PM
MitchAlsup's Avatar
MitchAlsup
How does the tow truck drag the car onto its flat bed with the car in park ?
Old Sep 16, 2020 | 09:41 PM
Racer X's Avatar
Racer X
tires skid..... or you can read post 7. Or they put both ends on dollies.
Old Sep 17, 2020 | 09:07 PM
bimmerborn's Avatar
bimmerborn
Folks thank you for your answers and the useful link. I take it that it is not possible to bump start a C8.
Old Sep 17, 2020 | 09:12 PM
SammyR's Avatar
SammyR
4th Gear
Typically you don't roll start automatic transmissions. The only way to find out would be to try it. Good luck and let us know how it turns out.
Old Sep 17, 2020 | 09:47 PM
ByRiver's Avatar
ByRiver
I haven't seen anyone push start a car since the 70's.
Replace the battery every four years or so, and you will never have to jump start it.
To Bump Start?
