Sponsored by: Wheel Design
Need Help with wheel width
Old Sep 22, 2020 | 08:59 PM
george vee's Avatar
george vee
2015 C7 of the Year Finalist
Default Need Help with wheel width
I'm looking to buy these Vertini Wheels, the issue is the rear wheel is 10 1/2in wide where the stock wheel is 11in wide. Will the 1/2in make a difference using the stock tires. Will it cause any issues.
The fronts are stock size
Old Sep 23, 2020 | 12:15 AM
Avanti's Avatar
Avanti
Google is your friend...
Old Sep 23, 2020 | 05:58 AM
Undy's Avatar
Undy
Be aware that the new wheel's offset and backspacing is as critical if not more so than wheel width.
Old Sep 23, 2020 | 07:42 AM
autodesign21's Avatar
autodesign21
1/2" wont, but pass on Vertini...
Old Sep 23, 2020 | 08:05 AM
JerryU's Avatar
JerryU
E-Ray, 3LZ, ZER, LIFT
Also wider wheels stiffen sidewall and can increase max lateral "g" force.
Also recall in ~1975 installing the 1st All-Terrain Radials available on my CJ5 Jeep. This is from a Press Release a few years ago:"BFGoodrich officially celebrates the 40th anniversary of the Radial All-Terrain T/A tire line at the SEMA Show in Las Vegas this week. BFGoodrich remains an all-terrain industry leader today, equipping millions of recreational light-truck, Jeep® and 4-wheel-drive enthusiasts for their daily adventures while empowering tough and stable performance for off-road racing.
In the mid-1970s, most tires were designed either for paved roads, or for off-road trails, but not for both. BFGoodrich engineers traveled to Baja California, Mexico, in 1975 to test a new concept ― a radial light-truck tire for off- and on-road use. They learned quickly that they could use the Baja peninsula as a real-life laboratory to develop tires. If the tires could withstand the grueling terrain of Baja, they could survive almost anywhere else."
But the tire specs said the minimum rim with was 1 inch wider than my 1974 CJ5, V8 Renegade wheels.
Called BF Goodrich and got one of their engineers who was involved in the tire testing in Baja. He said my 7 1/2 inch wide rims would work fine and give a softer ride on the highway, which I was looking for as well. He said in Baja they always use narrow rims because they would rather have a tire fail if hitting a rock versus having a wheel fail. They bring more tires than wheels! Bought them and ran at 16 psi. They worked fine off-road and on the highway!
Old Sep 23, 2020 | 09:12 AM
papillion's Avatar
papillion
Default Hmm?
If they don't make the 'right' size for the car, then they make the wrong size for you.
To Need Help with wheel width
