Sponsored by: Wheel Design
Issue with Memory Recall Driver Seat
Old Oct 4, 2020 | 09:06 AM
BalloonPilotC7Driver's Avatar
Default Issue with Memory Recall Driver Seat
I have me seat set to automatically move to “easy exit” when I shut the car off and to move into driver “position 1” memory when it starts.
Now suddenly, while the “easy exit” works, the memory recall doesn’t it moves the seat forward slightly and stops.
If I hold down the “driver position 1” button for the seat it will move it to the correct position.
Anyone else experienced this or have a fix?
Thanks.
Old Oct 4, 2020 | 09:48 AM
bad mooofooo's Avatar
bad mooofooo
Modified C8 of the Year 2021 Finalist
I think I've encountered this before but it was a specific scenario. If you don't touch anything and start the car, does it go to position 1?. Did you by chance switch to the other key fob?
Old Oct 4, 2020 | 09:58 AM
Bikerjulio's Avatar
Bikerjulio
Wait until you put it into drive.
Old Oct 4, 2020 | 10:22 AM
it doesn’t go to the correct position not matter what I do or don’t do. The other key fob is in a drawer in the house, haven’t touched it.
Old Oct 4, 2020 | 10:41 AM
papillion's Avatar
papillion
Default Hmm?
There have been similar posts for this very circumstance. The issue seems to be where you set the seat's exit position. If you move the seat all the way back and I mean all the way back (to max rear travel) and set it there, you have the problem. Solution is to move the seat all the way back and then slightly forward from this bump stop. Not much just a nudge forward of max back. Then set this as the exit point. The seat sensor doesn't index in the max aft position for some reason?
Old Oct 4, 2020 | 10:45 AM
manecda's Avatar
manecda
Similar problem with the C7. Papillion suggestion should fix your problem
Old Oct 4, 2020 | 12:52 PM
That seemed to work!!! Thank you so much!
Old Oct 4, 2020 | 12:58 PM
Foosh's Avatar
Foosh
I had two C7s (2014 and 2018), where it sporadically didn't work, about 1 out of 5 times. I tried all the "tricks" like making sure it wasn't against the backstop switch, etc, and both cars continued to exhibit the same behavior throughout my ownership.
My armchair theory is that like a PC, occasionally the Body Control Module software sometimes glitches. Sometimes, it would start moving, but not make it all the way back to desired position.
Old Oct 4, 2020 | 03:11 PM
papillion's Avatar
papillion
Default Ez
There is a Rick Conti channel video that covers setting the exit position on a C7. It is about all memory settings, but the seat exit issue is the first one. So you'll see the solution in the first minute or so. Same process with the C8,
To Issue with Memory Recall Driver Seat
