Sponsored by: Wheel Design
DIY engine cover modification.
Old Oct 4, 2020 | 07:26 PM
Steve388's Avatar
Steve388
Default DIY engine cover modification.
So ... I decided to try and do an engine cover modification myself. I used the C8 Corvette 2020 Engine Decal Graphics Kit from Corvettemods.com. The heat resistant decals were applied per the directions they came with the kit but I'm not sure they will stay intact without a heat resistant clear satin spray paint covering. Has anyone used or done something like this?
Here is my engine cover with the decals
Old Oct 4, 2020 | 08:08 PM
dcowles's Avatar
dcowles
Looks good. I don't see the kit on the web site. Do you have the direct link? What was the cost?
Old Oct 4, 2020 | 08:14 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
Looks very nice. I think your concerns may be correct but if you spray you may have to figure out a way so there's no overspray. Unless that's ok to do. The other thing is you'll need to get something that's also made to withstand heat, which isn't unusual to find but it'll also have to be compatible with the tape you put on. It'd be nice if there was some shop that did this for other cars and you could ask them some questions such as what type of spray to use. Good luck.
not the exact same---but just enter "engine detail graphics accent kit" in the first page search area.
Old Oct 4, 2020 | 11:18 PM
Looks good and hope they hold up well for you.
Unfortunately if you have problems, you should look at the threads in the Transactions Feedback section on that vendor.
To DIY engine cover modification.
