Sponsored by: Wheel Design
TPMS sync?
Old Oct 28, 2020 | 08:45 AM
RDSC8's Avatar
RDSC8
Default TPMS sync?
How do u sync new TPMS units once new wheels & tires are mounted?
Thxs.
Old Oct 28, 2020 | 08:56 AM
Foosh's Avatar
Foosh
They should "self-learn" with no human intervention. I swapped winter and summer tire sets back and forth on my C7s for 5 years, and the newly mounted set always synched within 5-10 miles.
Old Oct 28, 2020 | 04:15 PM
LT2/3LT's Avatar
LT2/3LT
Unmodified C8 of the Year 2021 Winner
RDS - Or you can follow the below as listed on page 260 of the owners manual -
Hope this helps!
TPMS Sensor Matching Process — Auto Learn Function Each TPMS sensor has a unique identification code. The identification code needs to be matched to a new tire/wheel position after rotating the tires or replacing one or more of the TPMS sensors. When a tire is installed, the vehicle must be stationary for about 20 minutes before the system recalculates. The following relearn process takes up to 10 minutes, driving at a minimum speed of 20 km/h (12 mph). A dash (-) or pressure value will display in the DIC. See Driver Information Center (DIC) 0 108. A warning message displays in the DIC if a problem occurs during the relearn process.
To TPMS sync?
