Powertrain
When we select track we have to choose between the follow
Wet
Dry
Sport 1
Sport 2
Race
I do know when selecting track mode that Race removes some of the nannies that are present in the other mode like wet or dry..
So good question as to which track mode the z button is linked too ?
Maybe one of CF resident experts or who have insiders at Gm could provide that answer.
I also would like to know and never thought about it until reading your question.
Powertrain- Track
Throttle Progression - Track
Trans Shift Mode - Track
AFM - Track
Traction and Stability Control - Normal (only option available). Track mode, only has Track.
PTM - PTM not available. In Track mode, PTM is available.
Steering - Sport. Track only has Track
Suspension - Sport. Track only has Track. (this setting only applies to Mag Ride equipped)
Brake Response - Sport. Track only has Track.
Wet
Dry
Sport 1
Sport 2
Race
Are those modes only for z51 or mag ride? I don't have those options on my non-z51?
So, just to be clear, if in the Z mode settings I select Powertrain to "Track" I will be getting the same full power of the engine as I do when operating in "Track Mode". { not Z mode }
2020:
1 - Included and only available with (FE4) Z51 performance suspension with Magnetic Selective Ride Control.
There is a recent Thread where the poster made a Video the clearly describes how to make your C8 a "different" car! That is what I have been doing for over a month when another poster made the suggestion.
I had been driving in Manual Mode to match the way I drove for 7 years in my 2014 Z51 and 2017 Grand Sport M7s. Seldom used more the 5th gear as did not often use the Interstate, which was the only place I used 7th. Seldom found a need for 6th in my back roads drive the 20 miles to town or when I was driving on our 55 mile speed limit rural roads where I typical drove at ~65 mph. The trip to town has many turns and stops and sections past farm fields with no homes, people or other cars (fun and corn and cotton don't care how fast I'm going!)
Then I found a way to set Z Mode to about match how I was driving and could do than in D not having to use Manual Mode.
SET Z MODE AND TRY
Z Mode is the only mode where you can set Power to Track without having to have all other features of Track Mode such as Ride, Steering, Brakes!
I have my Z MODE; Ride, Steering and Brakes set at SPORT and POWER set to Track. You can have Ride, Steering and Braking set to Touring if you like! This is what you will find:
- The car is seldom out of 5th at normal driving speeds (up to ~60 mph or higher) so you have the instant torque with modest extra throttle and not having the car downshift.
- It will hold in gear longer when accelerating from a slow speed and shift at a higher rpm
- When braking it will downshift at higher speeds and aggressively
- It stays in V8 Mode- NO V4.
- A benefit I find versus Manual Mode is when accelerating from a stop and making a turn. Then the steering wheel is a position where I can't shift out of 1st when desired because the unshift paddle is not in the proper position! See pic below of a common occurrence when I'm returning home and stopped in the 4 lane highway divider waiting for a gap in packs of traffic (speed limit 60 mph, cars often going past 70 mph.) In Z MODE it shifts near redline when accelerating to merge!
