Valve Spring Again!
Put a pic of three broken vales that occurred at, 150 miles below. These are unusual failures and it appears to be from what I have read and observe to be an internal metallurgical failure like a none metallic inclusion. If this were improper heat treatment that would affect large numbers of spring in a batch and probably picked up in a QA test etc.
There are very few failures reported on the forum and assuming a number more look at the potential population with vey rough numbers. GM has presented a concern over many months of production and just increased that past October. So from ~June through ~October. So using a SWAG of ~5000 cars that could have been affected that's 80,000 springs! It appears what has occurred is a very small percentage of the population. Forum members do have a way of turning anything into a Chicken Little, "The Sky's Falling" event!
As I recall GM had said, at least initially, IF a valve spring is found to be broken, replace just that one. If the engine had a CEL but a spring was not found then change all 16! Considering the percentage occurrence makes sense to me as it looks like a 99% probability the other 15 are fine. As was posted, warranty repairs occur all the time! Most spring failures reported on the forum didn't have a valve drop and hit a piston. BUT clearances are so small can see why it happened. To replace a piston they had to take the bottom end apart and would have been able to see any other defects. IMO the repair is likely to be fine.
So, your money BUT if you are getting a "good deal" I'd not have any concerns. Certainly better than "there will be others" that could be a year or more from now. You will have a 5 year warranty and it's NOT a CarFax Recordable Event. Heck I'll be looking to buy a Grand Sport before I reach 5 years!
"In that original TSB, General Motors stated the faulty valve springs were used in the production of the engines from June 1st – September 15th. However, more and more Corvette owners whose engine build dates were past September 15th were also experiencing broken valve springs....... The new end date for affected 6.2L engines is now October 7th, 2020."
Did not go back and try to find how many C8's were built in that 4+ month period but my prior post saying IF it were ~5000 that is ~80,000 springs in question. Although the forum is not a total answer we probably represent a sufficient number of failure reports (not many) that the odds of having one are very small.
Do what I did after passing 500 miles and hit near redline. In fact I do that often on fun 0 to 60 runs merging into traffic from a stop! I do it most days onto the 4 lane divided highway at the end of my street with traffic going 65/70 mph on the 60 mph speed limit highway. That no doubt stresses the springs the most! I've done that enough now that my concerns with >1000 miles are not an issue
Sure it can happen but so can some AH distracted looking at a text message or using their cell phone ruin my 60 year driving record of never having had an accident with another car! Much higher probability IMO
Hope your car will be fine. Odds are in your favor.
I'm new here and I'd like to ask your help. I'd like to buy a 2021.08. C8 Lt2 but I read in a previous post that some of the 2020 C8s may have a problem with the valve springs. Is it conceivable that the 2021 models are also affected by this? My VIN number is 51222....thanks in advance for the answers
