Stealth start up mode?
If I have to leave late at night or early in the morning, its a potential problem I would like to avoid.
So in the interest of not having my neighbors bring over pitchforks and torches, is there a way to start this thing without the "roar"?
*Please don't tell me for $30K more, I can buy an E Ray with Stealth. We all know this. What we need is a simple software update. Please.
** HERE IT IS **
"Good Neighbor Mode" on a Ford Mustang refers to a setting on the car's exhaust system that allows the driver to significantly quiet the engine noise, essentially acting as a "quiet start" feature, so as to not disturb neighbors, particularly during early morning or late night hours; it's essentially a way to control the volume of the engine sound depending on the time of day or situation, often accessible through the vehicle's settings menu.
WATCH THIS FORD GOOD NEIGHBOR DEMO >>
I think a software modification could be made to close the tailpipe flow control valves before the crank event on NPP cars, but that would not cut down on the louder exhaust sound that we hear for a period after the car starts, because in Tour mode those valves are already closed. They would have to modify the cold start strategy, and I do no know how much leeway they have there, since its in part motivated by emission control requirements. I know that in surveys GM has asked if owners would be interested in stealth start up mode so maybe they have something in mind. And of course with Eray there is stealth mode, but in that case the ICE is off.
Cold Start Strategy
"The catalyst must be warmed to efficiently reduce the emissions. The cold start strategy is to reduce the amount of time it takes to warm the catalyst. During a cold start, the engine spark timing is altered to allow the catalyst to warm quickly. This diagnostic monitors the following to build an exhaust energy model:
Spark advance
Engine airflow
Engine coolant temperature
Engine run time
Engine idle speed
Catalyst temperature
The actual model is then compared to the expected exhaust energy model. Fuel trim bias is used to keep the post catalyst air/fuel ratio within a predetermined range. This allows optimal catalyst efficiency under various operating conditions. The engine control module (ECM) constantly monitors how lean or rich the fuel trim bias is commanded, to determine if the fuel trim bias is greater than a calibrated amount."
Tailpipe Flow Control Valves close after start, in Tour Mode:
"Once the engine is running, accelerator pedal position, transmission gear and engine speed are used to determine the commanded state (open or closed) of the exhaust tailpipe valves.
Tour Mode: Exhaust tailpipe valves are closed when the engine is idling and during normal/non-aggressive driving. Valves open during aggressive driving."
Attached is a video showing the motion of the tailpipe flow control valve from a stone cold start. It is defaulted to open before the crank event. You will see it move immediately after the engine starts, to the closed position.
My mustang made me look like a good neighbor...the C8 makes me actually have to try. I chalk it up to an upgrade in performance car...so I have to be a bit more responsible.
If I did start the mustang in track mode it was insane loud...so I just actually have to be careful with this one
See post 29 at this link for video evidence of all this.
https://www.corvetteforum.com/forums...post1607148160
