Sponsored by: Wheel Design
Reverse Tilt Side Mirrors
Old Dec 15, 2020 | 07:53 AM
ASchaffer's Avatar
ASchaffer
Default Reverse Tilt Side Mirrors
Has anyone determined how to save the settings for how far you want your mirrors to dip when reversing? I cannot seem to figure it out, and they just point to the ground every time. Maybe I didn't save the memory correctly, or maybe the reverse dip doesn't save as a memory?
Thanks!
Old Dec 15, 2020 | 07:59 AM
Ken_C8's Avatar
Ken_C8
St. Jude Donor '09, '21
I don't think you can choose the position the reverse mirror tilt function goes to. I believe it's simply an on/off on whether they will dip to the setting that the factory determined (the ground).
Old Dec 15, 2020 | 08:05 AM
ASchaffer's Avatar
ASchaffer
Well that sucks. How does one reverse into a parking spot looking at the ground? I want to know if I am about to hit the side of another vehicle. LOL
Old Dec 15, 2020 | 08:36 AM
proeagles's Avatar
proeagles
Press the left (I think) button on the mirror settings and that will turn off the down mirror setting in reverse.
Old Dec 15, 2020 | 09:31 AM
Racer86's Avatar
Racer86
On your infotainment , go to settings, then vehicle, scroll down, you can turn the feature on or off or just one side.
Old Dec 15, 2020 | 09:55 AM
ASchaffer's Avatar
ASchaffer
Ya, I am just trying to figure out if there is a way to set them to a certain reverse level instead of all the way down. But I do know where the setting is for turning them on and off.
Old Dec 15, 2020 | 10:07 AM
Rabbi's Avatar
Rabbi
Banned Scam/Spammer
On the C7 I put the mirrors where I want them and simply set the memory.
Old Dec 15, 2020 | 10:15 AM
EasyLivin's Avatar
EasyLivin
I can't deactivate that feature fast enough on every car I drive... Blows my mind when that happens...
Old Dec 15, 2020 | 11:53 AM
ASchaffer's Avatar
ASchaffer
I had it on an F-Type Jag and an M3 BMW and you could set how much tilt to put on it when in reverse and it was perfect and Very useful when reverse parking next to someone. However with this car it doesn't seem to be an option and it just goes straight to the ground. I will also be disabling this. I submitted a "GMIdea" to them to maybe consider this as an over the air update in the future to tie it into the programming of your seat/mirror(while driving forward) like some of their competitors. I know the submission likely wont go anywhere, but its the thought that counts. HA!
Old Dec 15, 2020 | 12:11 PM
rider1's Avatar
rider1
I turned it off and just do it from the switch whenever I want it to tilt down, I also like to park as close to the curb as possible to give me and the car next door more room for door opening which is where it comes in real handy.
Old Dec 16, 2020 | 11:34 AM
Rabbi's Avatar
Rabbi
Banned Scam/Spammer
Mine stopped working right, I miss it. When backing into a spot I could see the parking stripes
Old Dec 16, 2020 | 11:36 AM
johnodrake's Avatar
johnodrake
Moderator
Same for Our MB's
Old Dec 16, 2020 | 11:52 AM
Losbot's Avatar
Losbot
I happen to like it. When I'm parallel parking, I don't want to curb my wheel.
Old Dec 16, 2020 | 02:47 PM
BIG Dave's Avatar
BIG Dave
i don’t believe the intention was to help prevent sideswiping another vehicle, it was to prevent scraping your rims against the curb resulting in “curb rash”.
Old Aug 3, 2022 | 11:31 AM
ebird40's Avatar
ebird40
1st Gear
I have a work around for that if you are the only driver.
set 1 and 2 memory settings the same then change mirror position on setting 2 to your desired back up position settings
then save
when you desire to back up choose setting 2 to get your mirrors in the desired locations.
Old Aug 3, 2022 | 04:32 PM
Red Mist Rulz's Avatar
Red Mist Rulz
The mirror down setting is intended to help when parallel parking next to a curb. To back into a parking space, use the backup camera. It can even display lines to help get you centered in the space.
Old Aug 3, 2022 | 04:41 PM
CarlosVP's Avatar
CarlosVP
Can you move the position of the mirrors when they are tilted? Maybe it remember the last tilted position
Old Sep 10, 2022 | 04:49 AM
Maverick62's Avatar
Maverick62
Cruising
Default Back up mirrors not returning to my saved position
I’ve got an issue with the back up mirrors settings not returning to my saved position after I put the car in drive. I’ve tried to save them back to desired angle but every time I back up the mirrors only come about halfway to my required angle. Anybody have similar experiences?
Old Sep 10, 2022 | 10:41 AM
RKCRLR's Avatar
RKCRLR
I had that problem with my C7. What triggered it in the C7 was if you interrupted memory position travel before it was finished. In my case the car would detect my wife's fob before it detected mine and start moving to her memory position. That in itself was frustrating because my knee would hit the hatch release and then I would have to get out and close it and be careful not to repeat the process. I would interrupt the travel by pressing my memory set button but that upset the mirrors. It was very unsettling to be merging onto the freeway in high traffic and find out my driver's side mirror was looking at the pavement. My workaround was to set only the passenger mirror to tilt down since I only used that feature when parallel parking. That way it wasn't a safety hazard when merging onto the freeway if the mirror didn't return to the proper position.
It was diagnosed as "operating as designed" and was never resolved. Perhaps a tech comment on the GM engineers that designed the system.
To Reverse Tilt Side Mirrors
