Sponsored by: Wheel Design
C8 Corvette Attack Blue Lavenza Performance Filter
Old Dec 23, 2020 | 09:08 AM
RPIDON's Avatar
RPIDON
Platinum Supporting Vendor
Default C8 Corvette Attack Blue Lavenza Performance Filter
Item #: T-1001-200T
Website link: https://www.rpidesigns.com/shop/item.aspx/c8-corvette-attack-blue-lavenza-performance-filter
Don't settle for stock when you can drop in some additional horsepower with the new Attack Blue Lavenza high-performance air filter for your NextGen Corvette.
FILTRATION
What good is more power if you're sacrificing filtration?
Attack Blue obtains these large numbers without forfeiting filtration by using proprietary advanced dry Nanotechnology.
For the first time more power and more filtration is NOT an oxymoron.
It's A FACT that nanofibers provide the absolute best airflow while at the same time providing the best filtration over other traditional filtration media.
This is indisputable.
Nanofibers are ultra-fine, so much smaller and thinner than traditional spun fibers.
This allows you to pack more filtering media in the same amount of space which will still allow air to flow but it creates a treacherous path for dirt and debris so it gets caught up and captured.
POWER
Attack Blue’s patent-pending design paid off. Independent testing showed an increase of 11hp by simply removing the stock filter and adding the Attack Blue.
Numbers you can actually feel. No tuning. No CEL’s. Nothing but power, torque, and filtration.
DRY - WASHABLE and REUSABLE
The Attack Blue C8 filter uses an engineered dry washable and reusable media.
To clean, just use soap and water!
NO oils, NO chemicals needed to clean or treat the filter.
Besides saving you money, you have the ability to run on a clean free-flowing filter more often.
SOUND
You will also hear your new-found power once the Attack Blue filter is installed.
Expect a slightly more aggressive cold start, a louder, deeper note once you lean into your pedal.
Independent testing shows Attack Blues proprietary dry Nanofibers capturing dirt down to an unbelievable SUB-micron level.
This submicron level of particulate retention increases engine life by reducing wear on internal engine surfaces.
Fitment: 2020, 2021 C8 Corvette
These make a great addition to any C8 Corvette!
If you would like to visit our Online Catalog for access to our entire
C8 Corvette Line of Parts and Merchandise Available for Sale,
just click the link below...
Website Link:
RPI Designs’ C8 Corvette Online Catalog
__________________
Old Dec 23, 2020 | 04:59 PM
pbarrows's Avatar
pbarrows
2020 C8 of the Year Finalist - Modified
Discount code not working.
Old Dec 24, 2020 | 07:33 AM
RPIDON's Avatar
RPIDON
Sorry but these are not able to be discounted
Old Dec 24, 2020 | 12:10 PM
pbarrows's Avatar
pbarrows
Then remove the discount code from the item that says it’s always active. SMH.
Old Dec 28, 2020 | 08:41 AM
RPIDON's Avatar
RPIDON
We did remove that line in the post. We apologize for any inconvenience that it may have caused you.
Old Dec 28, 2020 | 09:03 AM
jjsaustin's Avatar
jjsaustin
Pretty impressive reported power boost...
​​​​​​Have these results been independently verified by any forum members?
Any concerns with warranty?
​​​​​​Anyone getting one?
Old Dec 28, 2020 | 03:31 PM
Red Mist Rulz's Avatar
Red Mist Rulz
2.5% peak HP increase. Less at lower rpm. Suspect you could barely measure the difference in performance, much less feel it on the street.
Old Dec 31, 2020 | 10:28 AM
jcp911s's Avatar
jcp911s
All I know is my Lavazza filter makes a nice cup of coffee...
Old Jul 31, 2021 | 08:56 AM
RPIDON's Avatar
RPIDON
Make sure to check this item out
To C8 Corvette Attack Blue Lavenza Performance Filter
