C8 CORVETTE ATTACK BLUE LAVENZA PERFORMANCE FILTER
Why settle for the stock filter that came with your car when you can upgrade to this Attack Blue Lavenza Performance Filter from Southern Car Parts.
You'll instantly gain 11 horsepower and 9ft/lbs of torque by switching to this filter.
FILTRATION
What good is more power if you're sacrificing filtration? Attack Blue obtains these large numbers without forfeiting filtration by using proprietary advanced dry Nanotechnology.
For the first time more power and more filtration is NOT an oxymoron.
It's A FACT that nanofibers provide the absolute best airflow while at the same time providing the best filtration over other traditional filtration media.
This is indisputable. Nanofibers are ultra-fine, so much smaller and thinner than traditional spun fibers.
This allows you to pack more filtering media in the same amount of space which will still allow air to flow but it creates a treacherous path for dirt and debris so it gets caught up and captured.
POWER
Attack Blue's patent-pending design paid off. Independent testing showed an increase of 11hp by simply removing the stock filter and adding the Attack Blue.
Numbers you can actually feel. No tuning. No CEL's. Nothing but power, torque, and filtration.
DRY - WASHABLE and REUSABLE
The Attack Blue C8 filter uses an engineered dry washable and reusable media.
To clean, just use soap and water! NO oils, NO chemicals needed to clean or treat the filter.
Besides saving you money, you have the ability to run on a clean free-flowing filter more often.
SOUND
You will also hear your new-found power once the Attack Blue filter is installed.
Expect a slightly more aggressive cold start, a louder, deeper note once you lean into your pedal.
Independent testing shows Attack Blues proprietary dry Nanofibers capturing dirt down to an unbelievable SUB-micron level.
This submicron level of particulate retention increases engine life by reducing wear on internal engine surfaces.
