Sponsored by: Wheel Design
SD Card Missing
Old Jan 4, 2021 | 12:00 PM
RonnieC6Z's Avatar
RonnieC6Z
Default SD Card Missing
Quite often when starting the car I get a message on the right side of the dash display saying SD Card Missing. (the SD card for the navigation). If i hit the NAV icon, it shows that there is not an SD card. Upon turning the car off and starting it again, all is fine. I have taken the card out of its center console slot and put it back in, but the problem still exists. Anyone else have this problem and, if so, have the solution?
Old Jan 4, 2021 | 12:19 PM
Zymurgy's Avatar
Zymurgy
Moderator
I had this problem on my wife's 2020 XT4. Since it didn't happen all the time, I took a photo of the screen with the message and took the car to the dealer. They replaced the SD card and the problem has not reoccurred.
Old Jan 4, 2021 | 12:26 PM
bobbykart's Avatar
bobbykart
I hear you may have to remove and replace it, somehow it needs to click in.
Old Jan 4, 2021 | 01:26 PM
CitznFish's Avatar
CitznFish
I have the same intermittent issue with mine. But since I only use waze I ignore it. I also get a message about the PDR not liking the speed of my other SD card even though I have the right one and it works great.
Old Jan 4, 2021 | 08:19 PM
Avanti's Avatar
Avanti
I've seen repeated card problems where the fix was simply to find a card the system consistently "liked." Pitiful in this day and age, but seemingly true. All the best.
Old Jan 4, 2021 | 09:55 PM
MagicGlass's Avatar
MagicGlass
Try removing it and making sure the lock key is all the way in the unlock position. Then reformat the card from the car.
Old Jan 4, 2021 | 09:59 PM
16falcon's Avatar
16falcon
St. Jude Donor '21
For the PDR SD card that’s a good idea. The OP is having issues with his NAV SD card in the center console. I would try removing and reinserting it again. If you keep having issues they may need to replace the NAV SD card or the card reader in the center console.
Old Jan 5, 2021 | 09:03 AM
GPFboyJS's Avatar
GPFboyJS
I had this issue. You need to eject the NAV SD Card that is in the center console above the USB ports. Then re-insert the card. After doing this, never have had the issue again!
Old Jan 5, 2021 | 09:40 AM
Harry2's Avatar
Harry2
Same thing happened to me a few days after receipt, and it worked fine afterwards until my C8 went into storage.
Coincidently, I have a 2019 XT4 and the missing SD card message came on last week after 18 months of ownership, it went away after the next start up, but will monitor it now and know what to tell my service guy if it happens again -thanks Zymurgy!
Old Jan 5, 2021 | 12:48 PM
MagicGlass's Avatar
MagicGlass
Nav SD card? Is it factory installed? I didn't know we had such a thing
Old Jan 5, 2021 | 01:37 PM
Bikerjulio's Avatar
Bikerjulio
Yes it comes with the car and is specific to yout VIN.
Old Jan 5, 2021 | 01:43 PM
MagicGlass's Avatar
MagicGlass
Wow didn't know C8 was set up that way. When I get the car back from service I will go fishing for it.
To SD Card Missing
