Has anyone else had this problem: I was using my launch control and everything was working as it should but then it started only revving up to 1,500 RPMs when going through the process, not 3,500. Later in the day I tried it again and the same thing happened, it worked fine for a while but then would only rev to 1,500. I haven't tried it anymore to see if it started working again but obviously there's a problem. Has anyone else had that type of problem? Does it sound like a problem with the ECU? I would question it being a user error other than it working fine for a while. It seems to but perfect outside of that.
I definitely was pushing the brake hard enough because I know that's what they say but possibly not having the wheel completely straight. I'll give that a try.
