Sponsored by: Wheel Design
Engine Cover Project
Old Jan 8, 2021 | 12:11 AM
dcowles's Avatar
dcowles
Default Engine Cover Project
I have been waiting a year and a half for my C8 and I should finally get it sometime in February. Since it is getting closer, I decided to do a mod/project while waiting. I purchased this stock engine cover from someone on this forum and then proceeded to paint it (including the logo). I think it came out pretty good. I strongly recommend anyone to do this easy job to pass your time while you wait:
Items purchased (https://www.automotivetouchup.com)
Item No.: AER-AP - 12 Oz Aerosol Plastic Parts Adhesion Promoter
Item No.: AER-PR-Grey - 12 oz Aerosol Sandable Acrylic Lacquer Primer - Grey
Item No.: AER-BC - 12 oz Aerosol Spray Paint, 2020 Chevrolet Corvette: Torch Red 70
Item No.: AER-CC -
Description: 12 oz Aerosol High Gloss Clear Coat
1 set of Acrylic Paint Pens from Amazon (some else posted on the forum that they used these - thanks) 1 set of Acrylic Paint Pens from Amazon (some else posted on the forum that they used these - thanks)
Process:
1. Cleaned the cover
2. Taped off the brushed aluminum plates (should have removed them with fishing line. It would have been a little easier).
3. Sprayed on a coat of adhesion promoter
4. Sprayed 2 coats of primer
5. Sprayed 4 coats of base (15 min between coats)
6. Used the acrylic paint pens to paint the logo. This required about 5 coats of white and yellow paint to make the paint solid. After the white and yellow was painted, I painted 2 coats of black around the logo
7. 7 coats of clear
Hope this helps give someone some motivation.
Old Jan 8, 2021 | 12:12 AM
NextOne's Avatar
NextOne
You did a great job, especially on the logo. Might want to let folks know what steps you used, brand and color of paints, prep works, etc.
Old Jan 8, 2021 | 12:25 AM
Raz0r's Avatar
Raz0r
Well done!! Interested in the paints you used and how you did the Corvette logo.
Old Jan 8, 2021 | 12:37 AM
dcowles's Avatar
dcowles
Thanks guys. I've updated the post to include some detail
To Engine Cover Project
