Sponsored by: Wheel Design
Battery Voltage
Old Apr 22, 2021 | 04:43 PM
  #61
C8J's Avatar
C8J
Fyi, it is a charger, not a maintainer like the Ctek. I used it to return some less than OK batteries back to a useful condition.
Obviously you didn't read the reviews.
90% (76% 5 star and 14% 4 stars).✔
Old Apr 22, 2021 | 04:44 PM
  #62
RKCRLR's Avatar
RKCRLR
I use these on my generator, ATV, etc.:
https://www.ebay.com/itm/12286171979...oAAOSwB09YQTkF
Cheap enough to have several and not have to alternate. It is a true maintainer with a microprocessor, not just trickle charger. I also have a good maintainer for the "good" cars but wouldn't be concerned about the chap ones in a pinch.
Old Apr 22, 2021 | 04:54 PM
  #63
Phil1098's Avatar
Phil1098
I read the one star reviews to see if there was anything consistently poor. I have brought back batteries from the grave with my Optimate 6 by Tecmate, it's not some cheap POS either.
Old Apr 22, 2021 | 05:12 PM
  #64
Kingtal0n's Avatar
Kingtal0n
The Charger I just purchased (In Post #56) has exceeded my expectations.
  • You select between Auto, AGM, Motorcycle, and Repair Programs. Nothing else is needed by the user.
  • The only difference between Auto and Motorcycle is 8 vs 1.5 amp max charge rates possible.
  • AGM program uses a ramp up in voltage then down, then off (no charging) for a few seconds, then back on again. This is to prevent "boiling" the water out.
  • The repair cycle Ramps voltage up and then back down (pulse charging) vs keeping a sustained high voltage. If the battery checks out OK, repair will turn off within a few seconds!
I'm impressed (You know that is hard to do - LOL). For a $27 Charger that functions excellent with a complete digital display that shows you everything as it is going on - AMAZING!
I just bought a couple of those chargers because of your review. Thanks for sharing.
Old Apr 22, 2021 | 05:53 PM
  #65
C8J's Avatar
C8J
It will be interesting to hear your impression once you use it. Report back. The nice part is Amazon's 30 Day try it & then keep or return policy. It wasn't a high ticket item, but being inexpensive mad me try it and welcome the surprise on how well it works. If I didn't like it, I would certainly have returned it.
