Sponsored by: Wheel Design
C8 Convertible Rear view camera
Old Jan 17, 2021 | 07:01 AM
wevau's Avatar
wevau
3rd Gear
Default C8 Convertible Rear view camera
I live in Germany and have ordered a Corvette Cabrio C8. I have a question about this: The coupe has a rear camera on the roof for the rearview mirror. I can't see a camera like this on the convertible when the roof is open. Does the convertible not have this feature? Can you help me?? Many thanks to all of you. Wilf
Old Jan 17, 2021 | 08:54 AM
johnodrake's Avatar
johnodrake
Moderator
The camera is on the rear roof panel. It goes under the tonneau with the rest of the roof when you lower to top.
Old Jan 17, 2021 | 09:26 AM
proeagles's Avatar
proeagles
There is a camera on the HTC 1LT. It just goes away when the roof is retracted.
Old Jan 17, 2021 | 09:37 AM
JVi's Avatar
JVi
You don't need the camera with the roof off.
Old Jan 17, 2021 | 09:44 AM
Sallye M's Avatar
Sallye M
22 Hypersonic Grey HTC
Default 1LT Convertible has rearview mirror camera standard
Originally Posted by johnodrake
The camera is on the rear roof panel. It goes under the tonneau with the rest of the roof when you lower to top. (if you have a 2LT or 3LT trim level 1LT no camera)
The 1LT Convertible comes standard with the rearview mirror camera. When the top is down the camera goes away (but does not turn off) and you do not need the extra visibility the camera offers.
Last edited by Zymurgy; Jan 17, 2021 at 08:45 PM. Reason: camera functionality in convertible - zymurgy fixed quote tags
Old Jan 17, 2021 | 10:01 AM
RRvet's Avatar
RRvet
From: Retired from small University town in south/central part of Jersey & lives in South Carolina
Here's the HTC's camera in action.
Does it turn off when the top does down?
Old Jan 17, 2021 | 10:32 AM
16falcon's Avatar
16falcon
St. Jude Donor '21
Short answer is yes.
Long answer:
To activate the camera mirror, you flip a lever similar to one that would change an old style mirror to it’s “dimmed” mode. You pull it towards you and it tilts the mirror up slightly and turns on the camera. When you put the top down, the camera turns off, but now the mirror is tilted up, so in order to use the regular mirror, you still need to reach up and push the lever away from you in order to flip the angle of the mirror down. Once you do so it is back to however you had it set before.
So after typing the paragraph above, it seems to me I’m doing it wrong (in my defense, I’ve only had the car 4 days). If you intend to use the camera mirror with the top up (which I do), then I think if you have the top up, with the mirror in camera mode, and then put the top down, the camera will turn off, now adjust the mirror to the position you want WITHOUT flipping the lever. That way when the top goes up, it will already be in camera mode and when the top goes down it will switch to “mirror” mode and already be properly adjusted. No switch intervention required.
There has also been some discussion about it being hard to focus on the mirror camera. I would agree, but it hasn’t really bothered me. I wear progressive lenses in my glasses. When I look at the mirror I just use the middle of the lenses, the picture is perfectly readable for traffic although not crystal clear. I would have to tilt my head way up to use the bottom of the lenses to get a perfectly clear picture. Some people have suggested turning the camera mirror so it is directly facing the driver more makes it easier to see. That's probably a good idea for the coupe but would require readjusting the mirror every time you put the top down on the HTC.
Old Jan 17, 2021 | 11:32 AM
johnodrake's Avatar
johnodrake
Moderator
I stand corrected. I extrapolated from the Coupe
To C8 Convertible Rear view camera
