DCT Fluid Level Question
I do wonder why folks think adding 2 extra quarts for street use is advisable. Tremec has the fluid level check without the added 2 quarts. Add two extra quarts and you can't check the level. So at every filter change have no way to add what fluid is lost except to measure what drained, remove the whole Trunk liner and air filter to get to the plug on the top of the DCT to fill. A PIA and you will pay a dealer more labor than the fluid cost!
Yep fits what we face in our industry, "If Some Is Good, More Must Be Better! Can't tell a welder that shielding gas flow much over what is recommended causes turbulence, air entrainment, inferior weld quality and waste! Many know better!
So the procedure to find specific angle would be:
1. On level ground pull fill plug and check fluid level is correct for factory fill.
2. Raise side of car that fill plug is on.
3. Add the extra 2 quarts.
4. Lower car until fluid level is at bottom of fill plug, then replace fill plug.
5. With a Digital Level, record the angle at the bottom of transmission for future reference when checking "Track Fill" fluid level.
After the specific angle is known, checking "Track Fill" fluid level is just a matter of raising the car and getting transmission at the correct angle.
And lets face it, if you are tracking the car, you probably already have what you need to accomplish this task.
HTH
P.S. After determining the correct angle, I would etch it into the side of trans (next to fill plug) for future reference.
HTH
In fact thought the idea from another poster was a good easier way (lower pic which is also mine but from his idea!)
Simple way to add 2 quarts without removing anything! Just use funnel on hose end passed up into engine compartment from fluid check plug.
You are exactly right. It really isn't a performance issue, as much as a financial one. Just don't track it without the additional fluid.
Actually just testing to see who is awake!
I posted that as a way to fill NOT to measure level. Still think the fellow who came up with the idea of using a small valve was best. I just added a plug when completed in case the valve were to open!
Sounds like a 2 person job at the dealer doing in on a lift. One in the car heating up the fluid and running through the gears and one underneath getting their hands burned removing the plug and checking!
