Sponsored by: Wheel Design
Paint disappointment
Old Feb 6, 2021 | 06:41 PM
  #41
Nobull's Avatar
Nobull
Default Paint defects
This is not a big deal. I recently took delivery of a C8 HTC. Yes, it had the usual orange peal and other minor defects. My shop merely did a paint correction on the whole car. It is just a matter of properly buffing and rubbing the areas out. Subsequently, I had clear bra material (advanced version of Expel) applied to many areas of the car, and then the whole car was ceramic coated. I am extremely picky about the details of this car. I consider the result to be perfection. If you find the right shop and the right people it can be done. If you live near Sacramento, Ca. I can give you the shop that can do this. Many members of our Corvette Club use this shop and their results are the same. While I am at it for minor paint chips nothing beats the Dr. Color Chip kit: you must properly use it however. It took a week for the whole job, and cost a few bucks, but well worth it in my opinion
Old Feb 6, 2021 | 09:38 PM
  #42
jcp911s's Avatar
jcp911s
Originally Posted by rjktech
Your original comment indicated poor quality paint was ok because it’s a “60k car”.
So the next poorly painted example goes to you and you can pay 60k for it because we know you’ll be happy. That’s just fine. It’s your business decision. not mine.
No, my original comment indicated that comments like "poor quality" are subjective (and intellectually lazy), so please provide a quantitative metric... is it 7.5, 8.2.... 9.575? How poor is "Poor"....is it .5 standard deviations?.... deviations from..... what?....
Every responsible manufacturing process has to set measurable standards, and assure that the product fits within some measurable deviation +/- of these target performance objectives.... and I believe the Corvette QC people do a reasonably good job of this.... they set a price point, and do their due diligence to determine that this standard meets the requirements of some percentile of customers... call it 90% if you will.
Now, if you personally feel that their standards are below your personal preferences, then that is fine.... but that does not mean the Corvette is "poor quality".... it simply means you set a higher bar than 90% of Corvette buyers.... so just spend $$$ on professional paint correction, or buy another car....
Old Feb 6, 2021 | 10:42 PM
  #43
gkvetteuno's Avatar
gkvetteuno
Veteran: National Guard
What a coincidence. About 3 weeks after I picked up my 2021, while waxing it, I noticed the exact same circle etched into my paint and the exact same spot on the driver side deck lid. Makes one think someone on the assembly line is a little careless. Mine waxed out pretty good so not going to worry about breaking the factory paint to respray it.
Old Feb 7, 2021 | 06:56 AM
  #44
449er's Avatar
449er
CF Community Team
OP, Get the thin areas taken care of by your dealer & move on & enjoy your new car
Old Feb 7, 2021 | 10:07 AM
  #45
sly1's Avatar
sly1
Originally Posted by Alea_Iacta_Est
This is sage advice and I too would take option 2. Too many horror stories that the "attempted" fix creates even more issues. Unless it is blatant and visible by eye, you run a risk opening up a potential can of worms.
I'm friends with an outstanding paint / detail guy who specializes on cosmetic repairs on high end cars. The last couple of times I took my car to him, he advised me to do nothing. His advice was that unless you want to have entire panels repainted, spot repairs are just too risky. And if a panel is repainted he has to take before and after pictures to prove that the repaint was only a cosmetic repair. You don't want an appraiser reducing the value of your car because his paint meter detects different paint thickness.
So I'd also go with option 2. Maybe you can negotiate a free service from your GM dealer.
Old Feb 7, 2021 | 05:56 PM
  #46
thrilled's Avatar
thrilled
The problem is you actually need to go through with a fine tooth comb. As far as paint goes it’s a regular production car. You not going to get a $10k paint job.
Old Feb 7, 2021 | 06:04 PM
  #47
Skid Row Joe's Avatar
Skid Row Joe
Originally Posted by MMD
Don't be so overly simplistic in your thinking. It's apparent there are increasing issues being reported on these threads with paint quality again just like there was in 2018. This is an issue that is correctable. Has nothing to do with your weak $60K arguement. When GM installed their new paint shop most of the paint that came out in 2019 C7 was much better than what I am seeing posted here. Seems GM is pushing the edge on their production rates. It's my contention that doing this comes at a price. GM even admitted to this at the end if calendar year 2018 before they opened up the new plant. You can now throw away that overused adage some like to make here on CF. It doesn't hold water.
Correct!
The best time to get it corrected is now. I'm with the OP on this one too.
Old Feb 7, 2021 | 09:19 PM
  #48
JD'S WHITE 93's Avatar
JD'S WHITE 93
I’m the bodyshop manager at a Cadillac dealer and I would leave it alone.
Old Feb 7, 2021 | 11:54 PM
  #49
Panfish's Avatar
Panfish
But your Volvo is not as light at the Corvette nor does it have a composite body construction. That changes everything.
Huh? Pro shops can correct marginal GM quality, so it is something that doesn’t have to be. Sorry, I don’t buy these claims.
Old Feb 8, 2021 | 12:53 AM
  #50
MMD's Avatar
MMD
You can't compare painting a steel Volvo with painting a Corvette that is made from composites. Painting SMC composites, and the tech involved in doing this is far more complex than painting steel vehicles like Volvo. Kai Spande had mentioned this when GM was building the new paint shop. The Corvette’s sheet mounded compound (SMC) body panels contain resins, glues, and similar temperature-sensitive materials that out-gas when heated to 200+ degree Fahrenheit. The temperature environment in the spray booth has to be closely monitored because of this. You may have noticed on some pics it looks like small bubble had popped in the paint. That was a result of temperature controls slightly out of whack and QC people not catching these vehicles. The new paint shop is better than the old shop though. They had more out-gassing of paint in that shop which produced more bubbling. Volvo never has to deal with this problem.
The GM assembly plant does not employ detailers to correct paint. I don't think Volvo does either. That point is moot.
