Battery Life
know how long can the C8 sit ( days ) before the battery starts to show low voltage ??
Robert
c-8 will be similar. There is a normal drain on the battery when it is simply just sitting there. Computer memories, theft protection, etc. all have a drain on the battery.
Robert
The pic below is data from the C7 Service Manual shows with a battery in good condition you should be able to go 30 days and still start the car. In fact even with my weak battery I went on vacation for 2 1/2 weeks and never connected my battery charger. Some reported 4+ weeks sitting idle was no problem.
The problem is folks who drive very little! It takes a drive of .50 miles or more several times a week to keep it charged. A few trips 5 miles to the store drains more starting that the alienator can possible recharge!
Because I had issues with my two C4’s (yep leave an interior light on at night and the battery is dead in the morning) Not so foolish to do that as the interior lights stayed on for a short time. You were inside the house by then, didn’t recall you turned them on with a switch to find something. Do that a few times a conventional wet cell battery dies! Replace them, talk about hard to change batteries . in the C4 have to remove part of the fender and slide it our sideways!
When I “designed and built” my street rod bought a high, 125 amp alienator. Used a Red Top Optima battery. Initially always made sure I drove ~20 miles at least once a week (to be sure the oil was hot in the 8.2 Liter BB and “charge the battery.”) Battery died. PIA in a street rod where it’s inside the car that has electric doors! Since I wired the car myself said, "no way" the parasitic loses can be that high. Put an amp meter in the circuit and it was close to 70 ma (0.07 amps and at 12 volts = 0.84 Watts! Compare that with the smallest light bulb in your home- insignificant. However did the calculations and starting once a week that 8.2 Liter BB took time to start. That 850 Holley is not like fuel injection! When just cruising that 125 amp alternator was far from charging with the starting power lost! In 20 minutes is just not long enough
The C7 and C8 monitor current and shut down most power in ~10 minutes and all significant power in 30, as the Service Manual says.. Measured the “parasitic loses.” I measured about 30 ma. That is 0.030 amps or at 12 volts = 0.36 Watts!
However it is was my DD as was my 2017 Grand Sport and my current C8. Retired so don’t drive everyday AND may be a week if it’s raining. Rather have the wife’s SUV washed so use it! I very seldom use the equivalent to the GM battery charger. It’s an unnecessary PIA! As mentioned went on 2 ½ week vacation most summers and never plugged the charger in. (lots of lightning storms in Eastern SC and won’t take the risk and it’s unnecessary. Sold my 2017 Grand Sport after 3 ½ years, battery voltage (after the surface charge was depleated0 read fine!
However my experience with my street rod may also be of interest to those who find putting the car in is not a PIA. After that 1st Optima Red Top failed for what I finally measured power use and lack of charging time in ~20 mile drives two times per week, I replaced it with a Yellow Top Optima. Thankful for the warranty that covered the replacement even though it was not the battery failure, rather mine! Last year I replaced the Yellow Top- my 2nd in it's 21 years after ~9+ years. It was operating fine BUT with the battery inside the sedan and electric doors only operated with a remote- IF it failed at a car show would be a PIA! I do have a somewhat complex way to open a door if in the garage rather than break a window! However since that first six months of operation it has been on a charger 24/7. No question it has helped the battery life! But since I did all the wiring IF a lighting storm burns something out- I can fix it! In the C8 no way!
Robert
Getting to the C8 battery is not as bad as the C7 but it has a similar concern. In the C7, although not in the Owner's Manual or 4 volume Service Manual, I always removed the lower clips on the passenger side plastic rear wheel well cover to avoid ripping the unbound carpet under that area. There were posts where dealer techs ripped the rather flimsy carpet. Not hard. For sure those that use AAA- that person when they come to jump start etc will rip the carpet IF you don't pop the bottom clips off the plastic rear wheel well cover.
The C8 has something similar from comments by a number of posters. Good chance the AAA Tech may break a clip on one of the plastic side covers! Several members report doing that. One even commented when I suggested in my Tower Cover install to only use their fingers not the recommended trim tool. They said they cracked clips even when using their fingers! Even though I only use my fingers and pull to the car center NEVER up, I used an idea posted by C8J. I put used a silicone greased on all the clips. Makes insertion and removal easier.
Suggest all C9 owner's remove the 3 plastic panels required to access the battery when there is plenty of time and not rushed. Just do it carefully!
