OTA Updates - General Information
That said, I haven't had an OTA update in 2 years. When I tell it to check it says there are no updates available which is the same thing it did before when in fact there WERE updates available. I am half afraid to have any updates applied given they want to kill carplay and android auto functions.
Clearly this global B system or whatever GM calls it needs revision to how the firmware update system works.
There should be a mechanism where it expects to see a NO_UPDATE message that is timestamped with current date/time, etc. When the vehicle attemtps to check for OTA's if it doesn't receive a recent NO_UPDATE message, etc. it should tell you "OTA MALFUNCTION. DEALER SERVICE REQUIRED." or something to that effect.
The dealers have a tool that they can connect to the OBD2 port that processes all updates needed.
Fig. 1The new Vehicle Intelligence Platform (VIP) electrical architecture, introduced on some 2020 and 2021 model year vehicles, powers a new electronic system that is capable of managing up to 4.5 terabytes of data processing power per hour, which is a fivefold increase in capability over the previous Global A electrical architecture. On vehicles using the VIP architecture, virtually all modules can support OTA updates, which means that the OTA software is not only for the infotainment system.
When an OTA update has been downloaded to a vehicle and is available to be installed, a message is displayed on the infotainment screen notifying the driver of the impending update. The message to accept and install an OTA update will not appear until the minimum values for the battery State of Charge (SOC) and Outside Ambient Temperature (OAT) are met.
OTA Software Download
In order for an OTA update to be pushed to a vehicle, the vehicle must be parked for the entire download process. There is not a notification to the driver that the software update is being downloaded to the vehicle. Battery SOC and OAT values are not checked before a download. These checks are only performed once the software update is downloaded and ready to be installed.
The OTA software download can occur in increments. So if the vehicle is driven during the download process, the download will be paused until the vehicle is parked and download conditions are met again.
Installing an Update
Once the OTA software is downloaded, a message on the infotainment screen will display a prompt to accept the installation. The customer does not need to remain in the vehicle during the installation of the software. However, the vehicle cannot be driven during the installation and certain vehicle features may not be available. It’s not required for the ignition to be ON for the installation to begin.
Installation time will vary based on the size of the update. The average installation will take approximately 15 minutes. (Fig. 2) Depending on the module, it may take longer to complete. The “Accept” message on the infotainment screen will provide an estimation of the approximate installation time.
Fig. 2Deferring or Declining an Update
When an OTA update is downloaded, customers have the option to defer or decline the installation. The standard policy for OTA software updates is to set the customer notifications to 30 ignitions cycles. If the customer does not act upon the prompts within this counter, the update package is removed from the vehicle.
If a customer ignores the notification, the ignition cycle counter decreases by one immediately.
If the customer defers the installation by selecting the “Remind Me Later” option, the ignition cycle counter decreases by one, but it will not decrease again until after the customer-selected “Remind Me Later” period, regardless of the number of ignition cycles that occur during that period.
If the OTA update installation is deferred by the customer, it can be installed at a later date through the Vehicle Software menu under Settings > System on the infotainment screen. (Fig. 3)
If the customer selects the “Decline Update” option, the update package is immediately removed from the vehicle. In this case, the vehicle will not be re-enrolled to receive the OTA update at a later date, unless the update is a Field Action. OTA updates will not be installed in a vehicle without a customer’s consent.
Fig. 3Unable to Complete
There are a number of criteria that must be met in order to successfully complete the software update installation on a vehicle. The most common cause of being unable to complete an installation is the State of Charge (SOC) of the 12V battery. If the 12V battery does not meet the minimum SOC requirement of 70 percent or greater along with an Outside Ambient Temperature (OAT) greater than 14°F (-10°C), the OTA update installation will not occur. The colder the ambient air temperature is, the higher the target SOC becomes. To determine the battery SOC for VIP vehicles, go to BCM/12V Battery/Battery Sensor Module – State of Charge in GDS 2.
There may be other conditions that will affect an OTA update installation. If any of these conditions are present, a “Vehicle Conditions Not Ideal” message may display on the infotainment screen stating that conditions are not ideal to proceed with the update installation. These conditions do not indicate a failure; only that the vehicle does not meet all the criteria necessary to complete the OTA update installation. (Fig. 4)
Some customers may comment that the radio appears to stay on or is backlit after exiting the vehicle. If this occurs, it’s a telltale sign that an OTA update is in progress.
Fig. 4VIP (Vehicle Intelligence Platform) was formerly referred to as Global B architecture.
Note that it says that updates will never be applied without the customers consent.
Source: GM TechLink
20 minutes later, all done.
I do not remember declining; I hate going to dealerships if I don't have to. Is there any way to enable/authorize OTAs?
I'm hoping that the reason that nothing shows as available is because they roll out OTA updates in smaller batches and don't send it out to everyone at once...... maybe ????
I really don't want to have to take this to the dealer, IF an OTA update is available for this fix.
I also dropped both windows, JIC, and had the battery maintainer plugged in, found it, and then I selected "Install" from the menu (mine is a 2024 SR HTC Z51 FWIW).
The system message said "turn off the car" so I got out, pressed the Start button to turn it off, then had to select "Install" again, and off it went, countdown started.
Left it in the garage to do it's thing. 20 minutes later, checked and the dash was all dark. Hopped in, hit the "Start" button brake depressed and it fired up like normal.
I did not see a "completed successfully" message, but I may have missed it. I checked the Settings > Updates folder and there were "no updates available" and the one I just installed was listed as such.
I am going on the record that I and pretty tired of these otas by GM. My gmc truck never updates correctly and usually ends up at the dealer to have it finalized. The vette has pulled a few tricks in 2 1/2 years at some of the worst moments to try and update the car. Almost always the car acts crazy until it gets the update. My truck just flips out and ends up at the dealership. Very aggravating, I have more to do in my daily life than to tend to a vehicle that seems to need help updating something I could care less about. Just crank, run and don’t flip out is that to much to ask.
I've done the "hold down talk button for 20 seconds" reboot of the head unit a week or so ago. Is there anythign else I can do to possibly clear the cobwebs from this stupid thing?
2025 Stringray.
I guess there's no chance of this update being available to just download and put on a USB stick? Was able to update a previous Outback that way, even though the update files were a gray area they worked and was easier than taking it to dealer
If you can see the problem update,there should be 4 options
Install Schedule Remind Later and Decline.
Maybe try one of those options?
What year is yours? Mine's a 2025.
Can you see the stuck update in the Settings Updates display in the *infotainment screen? If so, it might let you Decline which might cancel and start over. Or Remind Later which could do the same. Lastly try Schedule and see what that does?
Maybe OnStar can do something to it for you - last resort?
