Sponsored by: Wheel Design
Engine Temp and Overheating??
Old Apr 4, 2021 | 07:15 PM
C8Torch's Avatar
C8Torch
Default Engine Temp and Overheating??
Folks,
'20 C8. All is well, except....when I get in line at a drive through, and engine is idling temp runs up to 203 pretty quickly. I turn off and wait for line to flow, restart, move, turn off. And this is in Winter.
Just wondering when it is 100 out side, AC is running and we are stuck in a traffic line of any kind, how hot do we let the engine temp get? Assuming fan et al are working correctly does it matter?? Or is there a hidden handshake amongst C8's to turn off and keep temps down until air can flow through ducts and cooling system.
TIA
C8 Torch
Old Apr 4, 2021 | 07:53 PM
Red Mist Rulz's Avatar
Red Mist Rulz
203 is not overheating. Water boils at 212F. With the recommended 60/40 water / coolant mix, with a pressurized system, boiling point is about 250 - 260F. Leave it idle and see if it gets hotter. The radiator fans should come on. If they don't, THAT'S a problem.
Old Apr 4, 2021 | 08:17 PM
Spamburger_Hamburger's Avatar
203 isn't remotely an issue.
Old Apr 4, 2021 | 08:21 PM
NoMatter's Avatar
NoMatter
What’s Next
I’ve tracked several cars hitting 230–240 water and oil temps no issue. Stop and go traffic will easily hit 200’s.
Old Apr 4, 2021 | 10:29 PM
gbf_98070's Avatar
gbf_98070
My 2017 Ram cycles from 194 to 204 and back again at 50 mph in 30 degree outside temps. That’s normal.
Old Apr 4, 2021 | 11:28 PM
JABCAT's Avatar
JABCAT
Isn’t there a red line on your coolant temp gauge somewhere around 260? 203 is not anywhere near overheating, & I definitely wouldn’t be turning off/re-starting the vehicle repeatedly sitting in a drive-thru line.
Old Apr 4, 2021 | 11:46 PM
Kaya1905's Avatar
Kaya1905
Overheating is common issue .
normal
Old Apr 5, 2021 | 01:00 AM
C8Torch's Avatar
C8Torch
Perfect thanks. should have thought that through a little more.
Old Apr 5, 2021 | 01:05 AM
C8Torch's Avatar
C8Torch
great explanation. thanks.
Old Apr 5, 2021 | 04:44 AM
Jacques Albrecht's Avatar
Jacques Albrecht
Originally Posted by C8Torch
Folks,
TIA
C8 Torch
Sitting at idle is the only way I can get my C8-Z51's engine oil up to proper operating temperature so that I can correctly check the oil level!!!
Old Apr 5, 2021 | 06:04 AM
Greg00Coupe's Avatar
Greg00Coupe
At 205 207 you are way under the thresholds. You’ll hear the fans and there are plenty of nannies built in to get you ample notification. C7s went into limp mode and I sure the c8 if it ever overheated would do the same.
I doubt gm would not have fixed the overheating issues of the c7 which were very limited but were real.
Old Apr 5, 2021 | 10:15 AM
SLWRNU's Avatar
SLWRNU
Interesting thread.
I have a friend with a 2021 HTC and we were slowly idling (parade like) for about 30 minutes and he told me he got a reduced power DIC message.
He said he turned off the engine for a short while and then it was ok.
Got me thinking though about sitting in traffic in hot summer days.
Old Apr 5, 2021 | 10:18 AM
LIE2ME's Avatar
LIE2ME
Veteran: Marine Corps
My C7 consistently ran at 210. Quite normal.....
Old Apr 5, 2021 | 10:36 AM
Zymurgy's Avatar
Zymurgy
Moderator
normal
Common issue on the C8? It certainly hasn't been reported here as a "common issue".
Old Apr 5, 2021 | 10:52 AM
Redc8z06's Avatar
Redc8z06
Thermostats open at a pretty high temp today, over 200, for emission reasons. In the old days we would install a 160 or 180 thermostat. What you are seeing is normal. Sometimes adding a water wetter like Red Line can help lower it a few degrees.
Old Apr 5, 2021 | 11:29 AM
JABCAT's Avatar
JABCAT
They were only on the supercharged Z06 when tracked, not when daily driven & there were no issues with the Stingray.
Old Apr 5, 2021 | 11:48 AM
24/Eray's Avatar
24/Eray
Optimizing the burn friend. These (and most) internal combustion engines are made to run in that range for efficiency.
Read this. Should help (100c is 212f)
https://business.inquirer.net/1609/g...ooling-systems
Will the car have the "most" hp available higher than that? No. It will pill timing. But mfrs care about emissions and fuel economy 1st
To Engine Temp and Overheating??
Old Apr 5, 2021 | 12:21 PM
Peppino Esposito's Avatar
Peppino Esposito
I'd venture to say the c8 thermostat is around 170 or 180, since that is what the coolant temps settle at on extended highway trips. Definitely opens well below 200. Fans only come on sometime after 200, though.
Old Apr 5, 2021 | 12:41 PM
Foosh's Avatar
Foosh
The boiling point of pressurized fluids is much higher than at ambient, sea-level, pressure (212ºF), which is one reason the system is pressurized along with increased flow in a pressurized system. System pressure combined with the antifreeze mixture raises the boiling point in the average vehicle to about 260ºF.
Old Apr 5, 2021 | 02:24 PM
MitchAlsup's Avatar
MitchAlsup
Do not worry about any water temperature under 230ºF or oil temperature under 275ºF.
