So my C8 is my 2nd Vette and I plan on keeping this one longer so I’m really just checking that my previous methods that “worked” are best practices or if I need to update my techniques.
For the interior, mostly it gets dusty on the dash. I’ve historically used a damp microfiber towel and just wiped it clean. Is this the best or should I be going a step further with Adam’s leather cleaner and their conditioner?
I did notice the other day I have some blue Jean “rub off” onto the Sky Cool Gray” interior. I haven’t tried cleaning this with water yet, but assume I might need Adams leather cleaner here, where a damp microfiber cloth might not cut it.
Summary: Use a soft cloth dampened with mild soap and water for maintenance cleaning. For stain removal and problem areas, use GM recommended stain remover and then GM recommended leather conditioner/restorer if necessary. However, I imagine that cleaners and conditioners from reputable companies are good.
A horsehair brush attachment for your vacuum is the best way to keep the dash looking like new. Vacuum it every other week or so - only takes a few minutes - and the dash will look like new forever. A wet cloth will just grind the dust/dirt into the creases in the dash material.
This.
Good advice.
I also use a soft paint brush in areas the vac brush can't reach to dislodge dust.
These methods worked to keep my previous 2002 Z06 looking like new.
I just purchased a Swiffer duster to use on the interior per recommendation of a friend. It did a good job removing dust from the dash and did not leave any streaks or marks. Much easier than using a vacuum.
