Sponsored by: Wheel Design
Track Mode Question
Old May 27, 2021 | 07:54 AM
psollitto's Avatar
psollitto
Default Track Mode Question
I have seen several videos where it was stated that Track Mode should ONLY be used on the track because of possible damage to the frame, etc. from a more "tightened" suspension. Would this apply to non-Z51 and non-Magnetic Ride cars? If it does, how is the suspension tightened without MRS?
Old May 27, 2021 | 08:14 AM
Majestic94's Avatar
Majestic94
That’s BS. No way track mode will damage your frame. They just say that to cover themselves for liability because track mode turns off some of the handling nannies. It also doesn’t shift into overdrive and turns off V4 mode so your gas mileage goes down below what GM rated it at for CAFE purposes.
Old May 27, 2021 | 08:28 AM
Spamburger_Hamburger's Avatar
Obviously track mode is a much rougher ride when you have mag ride. But I've never seen anything say it was a risk of damaging anything on the car using it on the road. Only cars with Mag-ride can adjust the suspension depending on driving mode, road conditions, etc...Z51 or not.
Old May 27, 2021 | 09:05 AM
JerryU's Avatar
JerryU
E-Ray, 3LZ, ZER, LIFT
Hmm, video's are wrong! Recall I used to quote something about "a problem" with wide wheels hitting pot holes if MRC set to Track. Sounded reasonable, as some sources mention (unlike frame bending which doesn't IMO!) BUT in an "Ask Tadge Forum Post" re wheel crack/bending issues he said something like, "I've seen comments about driving in Track will cause wheels to break. That is inaccurate. MRC at Track setting is not an issue even if hitting pot holes." (Looked for that "Ask Tadge Post," but did not locate. If it doesn't contribute to wheel cracks etc it won't bend frames!
Old May 27, 2021 | 07:36 PM
RussM05's Avatar
RussM05
In my personal opinion, track mode should only be used on the track. I switch between My Mode, tour and Sport modes on the street. Track is simply too harsh for me on the street.
Old May 27, 2021 | 08:11 PM
midengine's Avatar
midengine
funny thing is track mode IS the closest feeling to a proper supercar as they're typically pretty harsh rides.
Old May 27, 2021 | 08:23 PM
JerryU's Avatar
JerryU
Depends what is set in Track in Z Mode. I have Power set to Track, ride set to Sport (I prefer a stiffer ride and on our pot hole free roads (not perfect but no big holes) fine with me. Could set to Touring if desired. Have steering set to Sport and eBoost set to Track (certainly not like the aggressive feel of my 6 piston front 2017 Grand Sport under had braking..)
Even with Power set to Track the harshness of upshifting and downshifting is based on throttle. With light throttle pressure it's more aggressive than driving in Sport but not like when large throttle openings are used. Downshifting is also more aggressive then when driving in Sport BUT only very aggressive with hard braking.
I also switch between Z Mode and My Mode. Have My Mode set similar to Z Mode but can't set power. Have Ride, steering, and eBoost set the same. But even in my rural driving which includes no Interstate it will use all gears and go to V4 mode.
Old May 28, 2021 | 06:36 PM
Red Mist Rulz's Avatar
Red Mist Rulz
First off, if you don't have magnetic ride suspension track mode won't have any impact on the suspension, so it won't be any stiffer in track mode than in any other mode.
On the C7, the instructors at Ron Fellows strongly suggested not using track mode on the street (if you have MSRC) because the suspension was so stiff hitting a pothole could damage the shocks, not the frame. It would have to be a really huge impact to damage the frame.
The C8, mode for mode, rides softer than the C7 did. Using track mode on the street probably isn't as risky as it was on the C7. But I'd still avoid it on really rough roads.
Old May 28, 2021 | 06:49 PM
rgregory's Avatar
rgregory
When we designed shock pick up points in college for FSAE cars we always modeled the shock as a solid because in a very abrupt movement a shock is essentially solid. So regardless of a setting it doesn't matter GM had to design it to handle it.
Old May 28, 2021 | 06:54 PM
srewood's Avatar
srewood
My Z mode is set to pure track settings and I'm in z / manual for all corners pretty much. FE2 though. I only jump out of z / manual when cruising or in traffic. 🙄
To Track Mode Question
